PT 12 and MusicLab v4 VI Dilemma
I recently downloaded the v4 demos for MusicLab's VIs (RealLPC, RealStrat and RealEight) which all feature their new "double tracking" function that's meant to emulate double-tracking rhythm guitars. I first tested them out in AU Lab, and they worked as expected: when selecting, say, "RealLPC 2 stereo", it creates two instances of RealLPC being controlled by one MIDI channel/controller., and when "Double Tracking" is selected inside one of the instruments, you are playing through both instances simultaneously. You can then give each instance its own amp plug and you have a fair emulation of double-tracked rhythm guitars.
It should work this way in Pro Tools (and in Digital Performer, my other DAW, but that's a completely separate problem). I create a new stereo instrument track. From there, I select a multi-channel mono instrument version of RealLPC 2 (I've also tried doing this with the stereo instrument version), and while this appears to work a little better than the results in Digital Performer, I can only control the left-channel instrument with MIDI. Plus, both outputs are on the same track, meaning I can't put an amp sim on the individual channels, even if I could control both sides via MIDI. I'm sure there's something I'm overlooking here, since I assume people use multi-output VIs all the time (Superior Drummer, Kontakt, etc.) in PT. |
Re: PT 12 and MusicLab v4 VI Dilemma
edit for additional: pay no attention to Polich's response. Rather than answer your question he just posts his opinion of double tracking. While true to a certain extent he doesn't take into account those who either can't play guitar or get a guitarist in and record stuff. And that's where vi's come into play and there isn't anything wrong with that. |
I was a little surprised that PT wasn't able to load RealLPC with multiple outputs, but I'm brand new to PT and .aax. For the record, it did better than DP and .au did. |
I have a feeling it applies here as well as DP -- as I stated in my reply to your very helpful PM, I think MusicLab's VIs aren't showing up as multi-output instruments the way they're supposed to. They show up as multiple instances in AU Lab, controlled by one MIDI channel. One instance is inactive until you select "Double tracking", and then, both instances respond. This is the only piece of software that I've gotten to do this. PT 12.6 seems to have the same problem.
For Sale: MusicLab Real Guitar & Real Strat | Becharax | Buy & Sell | 4 | 10-30-2015 11:53 PM |
Amplesound Guitars Vs MusicLab Real Guitar | Becharax | Virtual Instruments | 2 | 07-04-2013 03:54 AM |
Musiclab plug-ins are not recognized | kaet | macOS | 1 | 09-14-2011 05:44 AM |
Musiclab RealStrat or PettinhouseDirect Guitar ??? | Rhapsody | Virtual Instruments | 2 | 05-03-2011 07:13 AM |
MusicLab Real Gtr on PT8 | TCLguy1 | Pro Tools TDM Systems (Mac) | 1 | 12-23-2008 12:26 AM |
