Jump to the next frame at playback stop
I have a referenced mac system comprising an HD OMNI / SYNC HD / AJA GEN 10 / AJA LHI. I have recently updated AJA LHI driver from 13.0.6 to 15.0.1, mainly for better performance/reliability in my editing software co-installed on the same system. Everything seems to run fine except that when I stop playback in PT, I've almost always a jump to the next frame during the next second at the end of playback . I didn't have this behavior previously. I do not see any discrepancies between timecode in the video and in PT. I have also performed a basic sync check (with CatchinSync) and everything seems to be aligned when playing. Is it a normal behavior (frame edge alignment at the end of the playback) ? Thanks! Last edited by damien78; 01-14-2019 at 12:04 AM. |
Re: Jump to the next frame at playback stop
I don't have an AJA card but this usually happens when you work in slip-mode. PT will stop and then depending on where between two frames you stopped re-park the picture to the nearest edge while the audio cursor is parked exactly where you stopped. When you switch to grid, PT will always stop on the frame edge and not make that jump after you hit stop. At least that's how it works on my machine. So: not a bug, more a feature. F.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Hi Frank,
Thanks for your answer. It was what I also suspected, but whatever mode - including the grid mode - I'm working with, I can see this behavior. Moreover there is always a small lag (half a second ??) between the stop and the jump to the next frame. I cannot spot any actual issue, but it makes me feel a bit nervous about my sync, since I didn't observed that jump with previous drivers. I will probably contact Avid/AJA support to make sure it is a normal edge alignment process. |
Whatever it is, it's not happening on my setup (see below) the lag in slip before the picture jumps is minimal. Instantaneous I'd say. It stops and immediately re-parks on the next frame edge. No lag.
You didn't say what version of PT you're using, so my guess it's because of the AJA driver since it wasn't the case before. But just guessing here... If your sync is OK in play, there's nothing to worry about really. F.
I updated to last version 2018.12 with old AJA drivers. No jump. Then I updated to AJA 15.0.1 and then noticed this behavior.
But you are probably right, and should not worry since I have no specific problem. |
I stop Playback and then jumps one frame ahead | Azul3 | Pro Tools 11 | 4 | 02-22-2016 09:02 PM |
Scroll behavior when you stop--stay where you stop, or go back to playback point? | bashville | Pro Tools 10 | 15 | 01-26-2013 05:56 AM |
why does my computer stop and jump during record.. | sethbrand | Pro Tools M-Powered (Win) | 1 | 01-06-2006 07:51 PM |
frame dropouts/frame jump when synced with 02rv2 | Alécio Costa | Pro Tools TDM Systems (Mac) | 1 | 11-24-2005 12:03 PM |
stop-frame in 24fps avid-playouts to pal video | Frank Kruse | Post - Surround - Video | 0 | 10-07-2003 08:29 AM |
