Old 03-22-2017, 02:12 PM
UndergroundLab UndergroundLab is offline
Default Merging clips together
Often, I will record certain segments of a song separately in the same track. However, even with the timing right, when I'm playing back the tracks, I often get a multisecond break of silence in between the recorded clips, making things sound fragmented. So, I'm wondering to save sanity, and make life easier, how to merge clips together into one so they flow smoothly. And as an answer in advance, I am such a perfectionist that even fret buzz gives me the obligation to redo the take, so I tend to record takes individually then piece them together (so, this acts ass the answer to, "Why Don't You Record It Altogether?" Also, my nerves will not stop to take one breath when recording).
If someone can direct me in how to merge tracks together, that'd be great.
Thanks,
UL
HP Envy @ 2.40Ghz
Windows 10.0
Pro Tools v. 12
16gb of RAM
Unsure of any firmware or drivers. Cannot find that information. Sandra reports take too long to complete, and time is a priority here.
Old 03-22-2017, 10:55 PM
edwinstar's Avatar
edwinstar edwinstar is offline
Default Re: Merging clips together
i suggest you use crossfades and zoom in to search for the best place for it. once everything sounds seamless you can consolidate the clips (=merge), but it should already sound seamless when crossfaded properly.
Gesendet von iPhone mit Tapatalk
Old 03-23-2017, 05:09 AM
JFreak's Avatar
JFreak JFreak is offline
Yep. Consolidate first and then remove unwanted clips from the clip list.
(there's a dropdown menu item "select unused" which selects everything not used in your mix. then "clear" lets you choose whether you want to just get rid of the clips in the clip menu or delete the file from the system altogether)
Janne
Exporting Clips as WAVs, clips dont highlight in list gigantorbuzz Pro Tools 10 6 08-05-2013 01:07 PM
Cross fades are not between clips but at the end or beginning of clips phatbeatstudio Pro Tools HDX & HD Native Systems (Mac) 2 09-10-2012 02:08 AM
Drag Clips = Delete Clips??? Connor macOS 2 07-09-2012 07:50 PM
Editing clips without creating new clips dimebagslash Pro Tools 10 2 07-04-2012 07:24 AM
Merging an OMF Peter Groom Pro Tools TDM Systems (Mac) 8 11-15-2006 07:20 PM
