Old 01-08-2019, 03:04 AM
Raoul23 Raoul23 is offline
Default Tempo mapping help
Hi guys
A session i had yesterday we track drums with the digital kit and the drummer struggled to play to a click. In the end i let the band play altogether and decided i would tempo map the session with identify beat. Everything is all good here so far but every no and then when the drummer does a drum fill he either speeds up or slows down quite a bit. What i'm trying to do is even out these fills but when i move the tempo of the bar to either slow it down or speed up it moves the tempo of the previous bar. Anyone on here shed some light advice on this and how i can just smooth out certain bars. At the moment im working with midi.
Thanks in advance
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 01-08-2019, 05:00 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Tempo mapping help
Originally Posted by Raoul23 View Post
Hi guys
Thanks in advance
Maybe try changing the track to samples mode instead of ticks.
Have you tried converting to audio and using beat detective
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-08-2019, 05:11 AM
Hi Chris
In samples the midi data doesn’t move if you change the tempo. It’s when in tick mode that if I try to change the tempo of one bar it changes the others.
I’ve not tried beat detective, must admit I’m not to familiar on how to work with that.
All I want to do is adjust the tempo of 1 bar. So if for example the piece is mainly floating around 120BPM but when he does a fill it goes to 110BMP for just that bar I want to increase the tempo so that it doesn’t sound like the song is dragging in that bar.
Raoul Crane
Old 01-08-2019, 09:10 AM
This would be the long way around, but the current version of Melodyne(outside of PT) can be used to smooth out tempo fluctuations(and boy I feel your pain). Sometimes, as a musician/engineer, I have to simply bite my tongue and let something sound like the players played it and give up on my idea of "right" or "perfect"
Back to Melodyne for an example: A friend's band uses some backing tracks in their live show and he had downloaded a midi file for a song and the midi was done to the original recording(with every tempo discrepancy included). At the gig, all the players had an awful time trying to follow the click that followed the track. I was able to drag the track into Melodyne, which analyzed and showed the erratic tempo, which I was then able to smooth out(probably went about 90-95% flat) and that made a huge difference for the band(of course, it would be best to fix the drums before anything else got recorded)
Old 01-08-2019, 02:34 PM
Thanks Albee I have the latest version of melodyne, I upgraded to 4 but liked the way version 3 worked better. Is there no way of doing this in ProTools. I thought it would have just been a case of grabbing the tempo line for that bar, setting the midi to ticks and moving it up or down to change the tempo
Raoul Crane
Old 01-08-2019, 04:21 PM
crizdee's Avatar
Ok i see what you're doing now. can't you just select the bar you're changing and use Event > Tempo and change just that bar. you also have options for the tempo change curve, constant/ stretch/ parabolic etc
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-09-2019, 09:29 AM
Originally Posted by crizdee View Post
Chris
That’s the one Crizdee!!! Thank you so much another awesome tip/trick added to my ProTools knowledge
Raoul Crane
Tempo Mapping??? gabrieljay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-19-2010 04:51 PM
Tempo Mapping KingStudios Pro Tools M-Powered (Mac) 0 06-05-2008 01:50 PM
tempo mapping skwad 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-15-2005 07:49 AM
tempo mapping in PT LE Brave Noise 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-25-2002 02:12 AM
Really Need Help With Tempo Mapping tomhartman Pro Tools TDM Systems (Mac) 1 08-03-2001 05:50 AM
