Old 03-16-2014, 11:25 AM
stevegalante stevegalante is offline
Default HD Native latency
I'm still on a HD3 Accel system and planning to upgrade.
I'm considering HD Native but I'm worried about latency during recording.
I've seen figures (all referred to 96KHz / 64 sample buffer, while I'm most of the time on 48 KHz / 128) basically saying the HD Native's latency would be double compared to my Accel system. Is this correct ?
If so, could it be a possible solution to use a "near-zero" latency interface like the Apollo for example ?
Thank you
http://www.stevegalante.com
Old 03-16-2014, 12:53 PM
Bookerv12 Bookerv12 is offline
Default Re: HD Native latency
Hey there,
I went from an HD4 to an HDN.
I had mostly moved away from tracking, but have done quite a bit with the new system.
I read through all of the numbers at different sampling rates, etc, and was worried....
After playing with buffer settings, not putting certain plugins on submixes, playing with turning delay compensation on and off, etc.,
I found that we get un-noticeable latency recording up to 8-10 simultaneous tracks just by keeping the plugins off the submaster... or disabling them upon record.
I've never really done more than 10-12 tracks simultaneously on this machine, and would be a little hesitant to try 20, but it really works great and has a lot more useable horsepower than the tdm system.
No regrets.
bookerv12
Old 03-16-2014, 04:26 PM
propower propower is offline
HD Accel latency = 2.4ms
Your particular tolerance for latency will be an entirely personal affair.
at 44.1 with HDN and AVID i/o you get:
32 samples 3.35ms
64 samples 4.80ms
128 7.68ms
256 13.52ms
LLM 1.9ms
LLM is the Low latency monitor path (no plugins allowed) at 44.1. This is pretty much the A/D D/A conversion time.
At 96kHz the A/D and D/A conversion times are less... so you get
64 samples 1.70ms
128 3.12ms
256 5.8ms
512 11.12ms
LLM 0.47ms
Simplest zero latency monitoring is with splitting signals after mic pres (or compressors if you have em) and doing it analog with a little verb added in for vibe. Sure - Apollo works too but that is a different workflow.
2017 27" iMac 3.8GHz i5, 1TB SSD
Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB
Musician: http://www.ivanlee.net/
Design Engineer: http://www.propowerinc.com/resume.html
Old 03-17-2014, 08:01 PM
Barry Johns Barry Johns is offline
32 samples 3.35ms
64 samples 4.80ms
128 7.68ms
256 13.52ms
LLM 1.9ms
64 samples 1.70ms
128 3.12ms
256 5.8ms
512 11.12ms
LLM 0.47ms
Why even bother with HDN if you have to do that. To me it's no different workflow than what LE users had to deal with for the last decade.
Buy a used TDM rig!
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors.
MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp
Old 03-17-2014, 08:16 PM
Originally Posted by Barry Johns View Post
Buy a used TDM rig!
He already owns one ... LOL
Old 03-17-2014, 08:18 PM
Exactly :)
Old 03-17-2014, 11:49 PM
JFreak's Avatar
JFreak JFreak is offline
I find this latency discussion not so constructive, because it really is low enough. Take a look at any session you have and zoom in to your bass track for example. I can assure you that every single note is 1-2ms off and you don't hear it until you zoom in and see it.
KNOWING what the latency is means nothing. FEELING that something is wrong means you need to fix it.
HDN is just as good as TDM ever was.
Janne
AAX native latency on HDX system Codo AAX Plug-ins 1 09-12-2013 03:47 PM
PT HD Native & HDX / latency? kirkbross Pro Tools HDX & HD Native Systems (Mac) 13 08-24-2013 09:48 AM
HD NATIVE vs HD TDM latency James Drake Pro Tools 10 20 06-19-2012 04:27 PM
omni/native latency vs mbox pro latency chrisdee Pro Tools HDX & HD Native Systems (Win) 34 03-30-2012 07:24 AM
HD Native latency CamM Pro Tools HDX & HD Native Systems (Mac) 2 11-30-2010 07:02 PM
