Old 01-10-2018, 07:57 PM
Grey Grey is offline
Default Re: DOES PT 10 HD work with Mavericks?
The only problem, I am having is getting a Mavericks Install.
Trying to update from HD8, to HD10.
Old 01-11-2018, 02:51 AM
crizdee's Avatar
crizdee crizdee is offline
Do you mean the Mavericks installer from apple...
https://support.apple.com/en_GB/downloads/mavericks
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-11-2018, 06:24 AM
Thanks Chris
I may be wrong??, but these are all Updates.
I did not not see a Installer for 10.9
Old 01-12-2018, 06:34 PM
WernerF WernerF is offline
I had to go to eBay and buy an installer. Pretty cheap and it’s worked great ever since. Needed the updated OS for various plugins and other stuff.
Old 01-13-2018, 02:22 AM
crizdee's Avatar
Thanks Chris
Yes sorry these are updates and you need the main installer.
I have found its possible to get El Cap / Sierra and High Sierra but anything before that is not available for download from apple.
As mentioned you can buy installers off ebay on usb sticks.
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-13-2018, 09:56 AM
Raoul23 Raoul23 is offline
I’ve just gone back to Lion I tried Maverick for a week and for me it was not as stable as Lion.
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 01-30-2018, 02:31 AM
Tried Maverick again this week but still no joy. The 2 plugins causing issues are soundtoys echo boy and slate VTM
If i open a session with a few Echo Boy instances in it just crashes. If i open the session with them inactive and then activate them all is ok.
VTM (1.1.13) If i click on this plugin in the session i get memory error issue and ProTools Crashes.
Anyone out there using these plugins in 10.9.5 with no issues??
Raoul Crane
Old 01-30-2018, 09:50 AM
Samanthas Dream Samanthas Dream is offline
Slate doesn’t work too well with that OS.
Echoboy should not be a problem, used it all the time.
15 years as PTHD User, Protools 2018 Ultimate, 24 Channel iCon D-Command, Avid Omni, Lynx Aurora 16, (2) BLA Modified 192 I/O’s, DigiPre, Way Too Many Outboard Compressors/EQ’s/ETC, where did all my money go????
Old 01-30-2018, 11:25 AM
TDM or native version of echo boy, and how many instances in a session :)
Raoul Crane
Old 01-30-2018, 01:11 PM
My work flow for TDM was always use TDM for tracking and them convert to Native for mixing. I used on average 4 instances of Echoboy per session, some more, some less. I’ve cant remember ever having an issue Exhoboy or any Soundtoys plugin.
Mbox 2 new driver for Mavericks just doesn't work arjohe FireWire & USB Audio Interfaces (Mac) 3 08-01-2014 04:09 PM
Mbox 2 new driver for Mavericks ust doesn't work arjohe Pro Tools 11 1 07-12-2014 02:52 AM
Artist Control STILL doesnt work with Mavericks!!! Hello? Anybody from AVID there? romanoffski Artist Series 4 06-15-2014 08:51 AM
Logic pro and logic pro x doesn't work after mavericks Sanderb Artist Series 3 12-20-2013 12:13 PM
Kontakt 5 does not work at all with Mavericks OSX 10.9. Dave S. Virtual Instruments 2 12-13-2013 12:13 AM
