Old 03-04-2004, 05:52 PM
technician technician is offline
Default windows xp services start/stop text file ?
I read some where not long ago about a way to make a single file control the start/stop of the services. You would make a text file with a line of code and the service you want to control and rename it into another type of file. I've searched the duc and various other music forums to find this and can't find it anywhere. it will be of great help to me if someone knows how I can do this. anyone know where to find this info? It would be greatly appreciated!
thanks
Old 03-04-2004, 06:28 PM
kojinsei kojinsei is offline
Default Re: windows xp services start/stop text file ?
I used to have a number of these. I'd love to see them again as well.
Old 03-04-2004, 07:05 PM
FatBelly FatBelly is offline
Try here.
Tweakxp.com
I hope this is what your were looking for.
FatBelly Slim
FatBelly Slim
Oh no, not the sprinklers again.
Old 03-04-2004, 07:13 PM
Thanks "FatBelly" but unfortunatly they don't have it. I looked there too, and found nothing about the text converstion for services. I can't find it anywhere! I searched the duc 5-6 times now, looking everywhere, and can't find it anywhere! Someone has to know where I can find this info! Anyone?
Old 03-04-2004, 07:59 PM
Unless I'm reading it wrong you may want to check the link I posted.
I don't know If you checked to link but it appears to explain exactly how to do what you're asking about.
But then again what do I know, I'm still using Cubase. LOL
FatBelly Slim
FatBelly Slim
Old 03-04-2004, 09:55 PM
nukmusic nukmusic is offline
You may be talking about creating different hardware profiles. Forgot where I saw it. But it was a way you could have difference hardware/software settings which would be selectable at bootup. sort of like dual-boot os drives.
Try: "Start/Control Panel/System/Hardware Profiles tab"
Docta'J
Download free music at
http://www.nukmusic.com
nEVER uNDERESTIMATE kNOWLEDGE
Old 03-05-2004, 04:37 AM
K.B. K.B. is offline
Services on / off? Won't that mean a reboot?
You want PTLE to run as fast as poss I assume?
In which case (here I go again) why don't you just opt for a multi-boot up option, and keep PTLE in its own boot up, with no other software running, and XP stripped right down. It's easy. Probably easier than what you're doing. I give a bit of a description of how I did this here. And there's some general advice about multi-booting here just in case you need it (which, I have a feeling, you don't)
Old 03-05-2004, 05:28 AM
bstaley bstaley is offline
I do exactly what you are talking about. Try this...paste the following text into a blank text file and save it to your desktop with the name "stop services.bat". You will run this file to shut down services and launch ProTools automatically. Here is the text:
sc stop wuauserv
sc stop eventsystem
sc stop browser
sc stop cryptsvc
sc stop defwatch
sc stop ersvc
sc stop gearsecurity
sc stop helpsvc
sc stop ipodservice
sc stop policyagent
sc stop spooler
sc stop samSs
sc stop lanmanserver
sc stop shellhwdetection
sc stop SSDPSRV
sc stop schedule
sc stop winvnc
sc stop WebClient
sc stop stisvc
sc stop W32Time
sc stop WZCSVC
"C:\Program Files\Digidesign\Pro Tools\ProToolsLE.exe"
Now create another text file called "restart services.bat" and paste in the following text:
sc start wuauserv
sc start eventsystem
sc start browser
sc start cryptsvc
sc start defwatch
sc start ersvc
sc start gearsecurity
sc start helpsvc
sc start ipodservice
sc start policyagent
sc start spooler
sc start samSs
sc start lanmanserver
sc start shellhwdetection
sc start SSDPSRV
sc start schedule
sc start winvnc
sc start WebClient
sc start stisvc
sc start W32Time
sc start WZCSVC
The second file is what you would run after you are done with ProTools. It will restart everything that you had previously shut off.
***NOTE***
These are services on MY system that I am comfortable shutting down. I did some research as I built this file. Go to someplace like tweakxp.com and learn what each of your services does before you try this. Make sure that you have the same services in both files. I won't be held responsible if your computer gets messed up. I'm only showing you the technique of how to do it.
LANPARTY UT nF3 250GB RT
Athlon 3400 DTR
G.SKILL 1G(512X2) F1-3200DSU2-1GBLC
ZALMAN CNPS7000B-CU RT
EnerMax EG365P-VE FMA 1.3 RT
GeForce2MX
Old 03-05-2004, 09:09 AM
Speedoo Speedoo is offline
I just created a new hardware profile that does what you want. When I boot my computer I'm given a choice of "default" or "ProTools" profiles. The ProTools profile has all non-essential services disabled. I learned how to do this, as well as which services can be disabled, at www.blackviper.com. It's true you have to manually disable each service the first time, but after you save the settings, you never have to do it again. Hope this helps.
Old 03-05-2004, 03:02 PM
bstaley, this is EXACTLY what I wanted! Thank you so much for the help! This is the biggest help I've had on this board so far! Thanks again! GREAT!!!
Windows services clausiii 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-04-2006 10:18 AM
stop / start services .bat files K.B. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-01-2006 01:40 PM
Windows Services... DesertTrax 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-14-2005 09:52 PM
Windows Services run down neomodo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-01-2005 12:06 AM
NT / MAC Cross Platform File Services Rob Nokes Pro Tools TDM Systems (Win) 14 06-22-1999 05:55 PM
