Closed Thread
Old 01-16-2024, 05:25 AM
WorldStudios WorldStudios is offline
Default 2023.12.1
I can't find any info on what is new/fixed. What's the story?
Johan Bejerholm
World Studios
Sweden
Phone +46707773443
Old 01-16-2024, 05:47 AM
its2loud its2loud is offline
Default Re: 2023.12.1
Mainly fixed an issue with offline bounced Rerenders and ADMs that had clicks and dropouts with certain plugins.
Old 01-16-2024, 06:37 AM
noiseboyuk noiseboyuk is offline
This is new out, right? Odd naming if so. And also odd there's no release notes. And even odder - the Windows Zip is an invalid file here, cannot open it. Downloaded twice, file size circa 3.9gb is actually larger than the advertised 3.79gb.
Maybe this download shouldn't be live yet?
Got excited for a moment that drag and drop from the clip bin in windows was back. I do hope that gets a maintenance update, that feels like a broken core workflow to me, akin to a car not being able to turn left.
Guy Rowland
www.guyrowland.co.uk
www.sound-on-screen.com - Original audio clips of movies, TV shows and games, licensed as regular production music.
PT 2024 Ultimate; W11 Pro; Ryzen 9 7900; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i
Macbook Air M2; 24gb RAM
Old 01-16-2024, 06:53 AM
JFreak's Avatar
JFreak JFreak is online now
Not so odd naming.
Take a quarterly release almost for granted now. As in 03/06/09/12 releases, and if there is a later bugfix for a said release (which carries a dot zero number even if it does not show) it gets a dot increase even if it was released later than the original month. This has been mostly in place since 2020 though it took Avid some time to make complete sense with naming again.
You guys have forgotten the times of paid upgrades. Say you bought upgrade for PT6.4(.0) you got tested bugfixes as PT6.4.x and untested customer service releases (for very specific issues) as PT6.4CSy.
So nothing new here. The "paid upgrade" is now quarterly, and exclusively available for active support plan holders
Janne
Old 01-16-2024, 06:56 AM
Originally Posted by JFreak View Post
Not so odd naming.
Gotya - so if your support lapsed on Jan 1 you'd still get this update?
All the more reason to get a drag and drop maintenance update, it should go to everyone who was on 2023.12.
Anyone on Windows actually get the zip file to work?
Guy Rowland
Old 01-16-2024, 07:07 AM
JFreak's Avatar
I am unable to test this, sorry
Janne
Old 01-16-2024, 07:16 AM
Yes, since it’s technically a .1 hot fix for the 2023.12 release.
Old 01-16-2024, 07:36 AM
RSLAMBERT RSLAMBERT is offline
It should fix the issue with clicks and pops when bouncing re-renders with the Atmos renderer.
Old 01-16-2024, 07:44 AM
IrelandM IrelandM is offline
Will give it a try.
Regards
Old 01-16-2024, 07:47 AM
thin ice thin ice is offline
Is there a list of the plugins noted to cause an issue? If a track is low in volume, it could be hard to hear in a full mix that was constructed on a previous version of Pro Tools without clicks or dropouts.
Mac Mini M1 16 GB
OS 12.7.4
PT 2024.3.1
Closed Thread
PT 2023.6 & Eucon 2023.6 Work Perfectly Natively, but no connection under Rosetta theodd Avid S1, S3, Dock and Control App 14 10-19-2023 07:23 PM
Does 2023.9 work with os 10.14.6 if i use the 2023.3 driver? [email protected] Pro Tools 7 09-29-2023 05:10 PM
does 2023.9 work in os10.14.6 if i use the 2023 hd driver? [email protected] Pro Tools 1 09-25-2023 09:13 AM
Eucon 2023.6 Crashes often when using PT 2023.3 Selle Sellink Pro Tools 3 08-06-2023 02:29 AM
Today's AIR FX and Instrument 2023.3 updates re-install 2023.2! off the wall Pro Tools 9 03-28-2023 10:33 AM
