Old 09-02-2014, 01:06 AM
soemoehtet soemoehtet is offline
Default " You are running out of CPU power. Reomove some Native Plug-ins or increase the CPU
Dear Sir,
I am having troubles that says
" You are running out of CPU power. Remove some Native Plug-ins or increase the CPU Usage Limit in the Playback Engine Dialog " and
" The audio device buffer Underflowed. If this occurs frequently, try decreasing the "H/W Buffer Size" in the Playback Engine panel or remove other devices from the audio firewire bus. (-6085) "
Please Help Me Out, i am facing those errors since i get the mbox pro in March, i have been searching to resolve these problems and i have tried many ways but can't fix it till now..
Anyone thank you so much, i am waiting the reponse
I am running with these.....
System -
Processor - Intel Core i7-4770, CPU 3.40GHz
Motherboard - Asus Z87-DELUXE
Memory(RAM) - 16GB Kingston 1600W
Graphic Card - NVIDIA GeForce GTX 660
Windows - Window 7 Ultimate Service Pack 1 32-bit operating system
Firewire Card - IEEE 1394b PCI Express Host Controller Single-lane Supports rate of 2.4Gbps
Interface - Avid Mbox Pro (3rd Generation)
Software - Protools 10.3.2
Plugins - Avid Virtual intruments, Native Instruments Guitar Rig 5, Addictive Drums 1.5.2, Korg Instument Plugins, Nexus2, Waves Complete 8
Old 09-02-2014, 02:16 AM
Southsidemusic's Avatar
Default Re: " You are running out of CPU power. Reomove some Native Plug-ins or increase the
If you had searched the forum you would have found this:
http://duc.avid.com/showthread.php?t=356183
Christopher
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 09-02-2014, 08:03 AM
Dear Christopher,
Yes, I had read the forum, but now i tried to uninstall the NVIDIA driver it gets better. Running out of CPU power does not happen for 3 or 4 hours.
I think its solved.
but now the Mbox pro sounds pop too much and cant even play for 10 sec it appears the error -6085 i am really tired of it.
Can you advice me that if i buy a new Mac Mini with Mevrick OS X, can i solve those problems??
My friend use Protools HD 10 with 002 and Gigabyte motherboard Dual core processor 4GB RAM win 7 32bit operation system, he has no error at all.
thank you so much,
Soe Moe Htet.
Old 09-02-2014, 11:45 AM
Hi
I don't think your computer needs to be changed for a Mac, you have a fast CPU and 16GB RAM which is plenty.
I would post a Sandra Report here and include any external Harddrives and other ext gear.
Are you sure you have the right driver installed? If you look in BIOS, turn OFF any floppy disc controller as some people have had issues with that even though they do NOT even have a floppy so turn off that controller and also check to see that ALL your plugins (3rd party) are up to date. Even though you dont use a bad plugin you can experience issues only having it in your folder.
Check these things and also trash preferences and databases and restart when you done the other things listed here.
Best
Chris
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Error message!! You are running out of CPU power. Remove some Native plug-ins... Jmissy87 Pro Tools 10 8 06-17-2013 06:51 PM
PLEASE HELP! PT 8 -- "running out of CPU power" at <15% of CPU usage jsbeeth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-01-2011 08:04 AM
"You are running out of CPU power" POPS, CLIKCS and HELL IN PT DCstudio10 Pro Tools M-Powered (Win) 24 07-12-2010 03:50 PM
"other" way to increase cpu power? pietro79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-04-2009 11:50 AM
Help! Error 9128 "Your'e running out of CPU power. Take out some plugins to free..." LATablette 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 03-26-2003 06:48 PM
