Re: External HDD with mixed Windows/Mac setup
I have to ask - why are you running Windoze on the Mac Mini? Is there some program you absolutely need to use for you to do that? If you're just using Pro Tools on both Macs then why not run OSX on the Mini? Would be a lot simpler than doing what you're doing. |
I work as a freelance product manager for assorted Pro Audio companies, and since the various hardware and software audio products I help design are meant to work with customers using the products with both Mac and Windows, I have to have access to both operating systems for when I am helping design/test/debug the different products I am involved in. The reason I use a Mac Mini for the Windows side (as opposed to some more conventional PC hardware) is because it is low-noise. All of the PCs I have owned before were extremely noisy, and purchasing or custom-building a "silent PC" was not as affordable or easy to me as simply buying a Mac Mini for $600 or so, installing Windows 7 on boot camp, and using it as a 100% Windows machine. Whether it is during recording, or just listening to music while working on a product spec, I want my PC to be as silent as possible :) I suppose I could boot up the Mini to the original Mac Partition when I am doing mixes, and use it in Windows the rest of the time, but that's a bit more complex solution that I'd like. Ideally the Windows machine could stay booted up in Windows at all times, and work with the external thunderbolt drive. Last edited by DanSteinberg; 05-17-2013 at 12:28 PM. |
So just to confirm before I buy the (admittedly very affordable) software, it would presumably allow me to use the following workflow below? 1-Install NTFS-Mac 2-Format my external thunderbolt drive as NTFS, as opposed to fat-32 3-The Mac will now be able to provide play AND record functions of OS X Pro Tools, and do so at speeds and stability that will be sufficient for Pro Tools with a large number of tracks? This is the main question for me, that whatever special magic that NTFS-drive is doing to make the NTFS format drive "writable" on the Mac, does so without any performance hit that messes up Pro Tools. The whole reason I bought a drive with the specific combination of both an SSD disc on the inside, and a thunderbolt interface on the outside, was to be able to be really confident that I had a nice fast laptop recording solution, that Pro Tools could keep up with, and do so on a session using recording a large number of tracks at once onto the Powerbook laptop 4-Since the drive is now NTFS and not fat-32, it can be used to play and record on Pro Tools, on my Windows machine, since Pro Tools is happy with NTFS drives Edit: Looks like the MTFS-Mac product has a free 10 day demo, so I will certainly give this product a try and see how it fares. Thanks to everyone so far for all the great assistance so far! Last edited by DanSteinberg; 05-17-2013 at 01:11 PM. |
Mbox 3 Pro & external HD setup | ChubB79 | macOS | 7 | 02-04-2011 03:43 PM |
Recorded in osx mixed in windows | KOLT | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-13-2005 07:17 AM |
External HD Setup | riotbeats | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 02-27-2005 06:51 PM |
how do I setup my external FW Harddrive with my PB | 72reissue | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-27-2005 06:38 PM |
PT with external mixer - What do you think of this setup? | Richard Warren | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 07-12-2002 12:55 AM |
