Old 06-11-2012, 02:07 PM
mmk mmk is offline
Default "A device attatched to the system is not functioning"
Very weird error. Not sure how to fix this. Everything was working fine until today. Not sure what happened. I can't open up any sessions because it tells me "A device attatched to the system is not functioning"
I am using Pro tools 10.2.0 Windows 7 64 bit and an 003 rack. I have been having some problems with it before but nothing like this...
anyone had this problem before and is there a solution for it?
Also i have to unplug / replug the ilok every time i boot the computer its annoying anyone know a fix for that?
Old 06-11-2012, 02:33 PM
mmk mmk is offline
Default Re: "A device attatched to the system is not functioning"
actually seems to be the "Avid HD Driver" which is malfunctioning. can't uninstall it either! anyone know how to remove it without going to the control panel?
Strange System.log Event "Non-smartcard device launched pcscd" Repeating... dford macOS 2 05-10-2013 11:57 AM
DICE chipset+PT10="ASIO device properties have been changed by the device" Funk-O-Meter Windows 5 12-19-2012 05:12 PM
Error at startup: "Your audio device is configured with an unsupported buffer..." Kronos78 Windows 0 05-03-2011 01:39 PM
Difference between "system" and "CPU" usage? ashdot Pro Tools TDM Systems (Mac) 1 05-01-2003 02:01 PM
Difference between "system" and "CPU" usage? ashdot 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-01-2003 01:51 PM
