Old 12-02-2010, 07:42 PM
basslik's Avatar
basslik basslik is offline
Default General consensus PT9
I have had pt9 for a couple of weeks now, haven't even messed with it yet cause I'm waiting on a new desk to put my monitors on. I will be tracking a band in a couple of weeks and I hope I don't run into any snags during the session? hows things working for everyone?
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
Old 12-02-2010, 07:48 PM
Draulym Draulym is offline
Default Re: General consensus PT9
Mine's been mixed - set up my laptop with my A&H Zed-R16 at home for tracking a band - worked like a charm!! Got to the recording space (the bands rehersal room) the next day & Nada - PT would launch but not record, playback anything - lucky I had set up reaper "just in case" - did all the tracking on reaper!
Mixing & editing on my desktop system so far is all good!!!
Old 12-02-2010, 07:49 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Default
The worst thing u can do is wait to use it @ the last minute..
For me "now" its like all prior versions were (very stable).. but the 1st week, HORRIBLE!!!!!!
Edit: issues I had were due to me not running on Legacy.. once I got legacy going, its been Tamara on my lap with Pizza Hut & Papa Johns good
Sent from Epic 4G Using Tapatalk on'eim...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 12-02-2010, 07:52 PM
Dism Dism is offline
Personally, I had no "1st week" troubles.
I have not had a single crash, no weird errors, no stutters, no problems opening anything... it just works.
I'm still a little shocked every time I run it... The stability has been nothing short of brilliant.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 12-02-2010, 09:28 PM
smpkeys smpkeys is offline
Smile Re: General consensus PT9
Originally Posted by Keybeeetsss View Post
The worst thing u can do is wait to use it @ the last minute...
Well said. I've got a pretty stable 8.0.1 cs2 build running now and tracked a band today and also monday this week. (at 32 buffers and no hickups I might add!) Why haven't I installed PT 9 yet?
I haven't had a 2 or 3 day period to do a clean OS install, get plugs installed and auth'd, ect.... and even when I do , I'll still have my PT 8 drive ready to boot from just in case.
If you have paying work coming up and not the time to properly set up and test - wait till you do !
2010 Mac Pro, 3.46 GHz 6 Core Xeon,32 GB RAM, OSX 10.9.5, PT 12.4, RME Fireface UFX, Command 8, Mytek 8x192, SSD evo on System,Audio&Samples on spinner drives WD SATA 64mb Cache
Old 12-03-2010, 02:56 AM
geetarpicker geetarpicker is offline
I picked up PT9 on the 2nd day it was out and still have yet to get it running right but I'm getting closer. I finally got the performance much improved with my UAD2 quad, but now I'm having this consistent crashing issue with save or save as. Seem if I call up a session with fairly high UAD2 usage about 1 in 20 or 30 saves will crash the system hard.
I've been going through my system and did discover two big issues that I corrected. One was my UAD2 install was somehow off, and the LEDs on the UAD card were not showing the typical patterns. A full uninstall and reinstall fixed that, and I went from a minimum of 1024 samples working down to a low 128 now. 2nd it turned out that my OCZ ram memory was throwing errors, and I just changed the ram out for Corsair and that issue seems to have gone away and memtest+ on the new ram shows up clean. I've since reinstalled all my audio software but still have the save crashes issues in PT9. It's possible that the bad ram I had caused some corruption of my Windows 7 64 bit install, though I wasn't having any issues running Reaper and Sonar on the system even with the flalky ram and somewhat off UAD2 install. Any way it appears that PT9 is pickier about it's environment than my other two DAWs.
I be interested to know if anyone has any save issues? It seems that the save function is the quickest way I can tempt it to crash.
Plugin wise I think my modest list of plugins are all thought to be ok with PT, being Waves Renaissance collection, Melodyn Editor, and one UAD2 quad.
Old 12-03-2010, 03:07 AM
djgizmo djgizmo is offline
So far so good. even played around with the built in Digitranslator :)
Lovein it. Love the new shortcut for new playlists and being able to create a send>aux track on the fly.
This is how pro tools should have been. I think this is the beginning of a very very nice relationship with Avid and the rest of the world.
Old 12-03-2010, 07:54 AM
TOM@METRO's Avatar
My assertion errors on saving were cured by updating all plug-ins and pointing all VIs to the correct content location, then trashing all preferences. (Waves seems stable with V 7r8 and up.)
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 12-03-2010, 08:00 AM
danander11 danander11 is offline
Well, I'm still about 70% deaf from chemo and radiation treatments, so I haven't exactly been running the doors off it, but I fire it up every day since it's release and noodle along with it with no problems whatsoever, excepting the initial install hiccup.
I did experience a thing with wrapped Revererate.. but once I installed the latest version that included RTAS.. no probs.
I think with 9 you will need to make sure ALL of your plugs and such are up to date or risk running into issues..
9 Still gets a huge thumbs-up from me.
Here I am,
after time not long...
and thankful for the break,
What I found when I got there,
was that I couldn't stay away!
Hobo Shave!
Old 12-03-2010, 08:04 AM
apesong's Avatar
apesong apesong is offline
So far so good, for me. Recording, Mixing, plug-ins, etc, all fine.
[IMG] code is Off
consensus on 10? basslik macOS 39 03-07-2012 09:42 AM
PT 10 & DIGI002 - What's the consensus? Darney macOS 7 11-05-2011 07:29 PM
PT 8 on XP, where is it at, consensus? dubrichie Pro Tools TDM Systems (Win) 12 03-15-2010 08:54 PM
10.4.11 consensus Phil Jeffers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-26-2007 01:36 PM
6.9-Whats the consensus? Mt.Everest Pro Tools TDM Systems (Mac) 22 04-22-2005 06:15 PM
