Recording with Eleven rack issue
I have just purchased the Eleven Rack however I am having problems recording with it in protools. While I can record via S/PDIF there is supposed to be an I/O option enabling you to choose Eleven Rig L/R and record via the USB cable. This isn't showing up for me as an option. I did not install the protools software that came with the rack as I already had v8.0.3 installed. Is anyone able to assist?
Re: Recording with Eleven rack issue
You might try going to the IO settings, the ones that show the available inputs and outputs, and hitting the DEFAULT button. See if they then show up.
Also, make sure that you installed the Eleven Rack driver. |
Go to the Digi webpage, support, and find CS updates. Download the special 8.0.3 cs update reg. eleven rack.
You should be able to see ins in the I/O menu. (build up your I/O settings, if its not there allready; options menu)
[email protected] |
Many thanks for the helpful posts. I tried hitting default in the I/O settings but had no luck. I then downloaded the 8.0.3 CS update and then went into the I/O setup. When the Eleven Rack didn't show up there I followed your advice and went to the import settings and managed to successfully add the Eleven Rack as an I/O path and it now shows up as an I/O option when I am in the mix window. So I think the problem is now solved. Again thanks heaps for the very prompt and helpful advice.
Issue with i/o after eleven rack use | jimbridgman | Eleven Rack | 2 | 02-11-2014 09:14 PM |
Issue with recording with Eleven Rack Patches into Logic Pro | gregoryl | Eleven Rack | 7 | 08-19-2013 07:42 AM |
Issue recording through Eleven Rack | redd1971 | Eleven Rack | 3 | 07-23-2012 06:53 PM |
Eleven rack issue | dndunlap | Eleven Rack | 4 | 03-08-2011 11:35 AM |
Eleven Rack with HD issue | Touchwood Studios | Pro Tools TDM Systems (Mac) | 6 | 10-09-2009 12:22 PM |
