Old 06-23-2009, 04:03 PM
Sheldon Radford's Avatar
Sheldon Radford Sheldon Radford is offline
Default Re: CS 48 mic pres?
Hi Brad,
I meant SC 48 mic pre. I edited the original post to make this clearer.
Sheldon
Old 06-23-2009, 06:19 PM
digimidi's Avatar
digimidi digimidi is offline
Just to clarify, the Digidesign PRE is 3 db steps. No digital control.
Gil
Gil Gowing
Principal
Digimidi Technical Services
Old 06-23-2009, 06:21 PM
BradLyons BradLyons is offline
<-------is going to go stand in da cornuh now cause I feel stoopit!
Thank you,
Brad Lyons
www.howavl.com
Old 06-23-2009, 07:24 PM
digidesigner digidesigner is offline
Thanks Sheldon and Gil, in case you are willing to share some additional info, what makes a mic pre different in the situation where three consoles share a mic and might all have +48 turned on?
Old 06-24-2009, 10:10 AM
There are really two issues that come into play...
In a live setting it's not uncommon to split a mic 2, 3 or even 4 ways, all done passively (with wiring and sometimes transformers). In this case the mic is wired in parallel to each console, so the mic pre's input impedance needs to be high enough that this passive split doesn't cause significant signal loss, but not so high that it's susceptible to noise. In the studio the mic is usually only connected to one pre.
Re +48V: on a live gig it's possible to have multiple consoles all feeding phantom power through the passive split (unless transformers are used). In this case, there must be sufficient protection to ensure the multiple +48 V sources don't damage the mic pre. This is done with a simple diode protection scheme.
Sheldon
  #16
Old 06-24-2009, 12:53 PM
Sheldon
Hi Sheldon and thank you for the answer. But are you saying DigiPre input impedance would not suit into this type of situation? (being one of 4 "consoles" lets say in live recording situation?) Also does DigiPre lack of such diode protection scheme?
  #17
Old 07-09-2009, 10:23 AM
mackerr mackerr is offline
Originally Posted by BradLyons View Post
Are you saying that the 6dB stepped-gain is on THE PRE (outboard unit) or on the console's pres? I'M CONFUSED NOW!
Re: the gain step size.
The Mix Rack/SC 48 mic pre uses a combination of analog and digital gain over its full range. The analog gain is relay-switched in 6 dB steps. In between these steps digital gain is then used to give 0.1 dB gain increments. From a user's perspective you have full control of a mic pre from +10 dB to +60 dB in 0.1 dB gain increments (the transitions between analog and digital gain are handled automatically as the gain is adjusted). This hybrid approach gives the best combination of fine control and high quality audio performance.
My bold.
Mac
Audio plumber since 1976
Omni Pres/Converters vs. Other Pres/Converters Infiltrator Pro Tools HDX & HD Native Systems (Mac) 1 01-15-2012 10:28 PM
What's better... BLA 002R Mod Pres or DigiMax FS Pres via Lightpipe? DeyBwah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-04-2010 07:39 PM
Digi max fs pres vs. 003 pres. KevinAllen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 01-26-2010 05:18 PM
budget tube pres vs. 002R's pres davetron5000 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 10-12-2003 05:04 AM
001 pres or Mackie pres??? QuikDraw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 07-04-2002 12:39 AM
