Mbox 2 mini - No output out of right channel?? Help!
Purchased an mbox 2 mini recently and after installing everything on my intel imac i discovered i could only get output out of the left channel. The right channel, if i turned it up really loud, i could get a slight sound but very distorted.
I tried coming out of the headphone jack as well but this also wouldn't work. Im going to take it into sound control later to test it but i wondered if anyone knew of this fault? Is it software? or hardware?? |
Re: Mbox 2 mini - No output out of right channel?? Help!
What are you playing back? If you setup a master track, do you see both meters light up? Are you sure you didn't accidentally record a mono signal (like a single mic or guitar) onto a stereo track?
I have the same problem. My Mbox was working fine and suddenly the right channel stop working (only if I turn it up really loud you can hear it slightly).
This has happened for all outputs on the interface (front/headphones & back/main outs). Is not a DAW routing problem because I'm testing it with music played in quiktime/VLC on my macbook as well. I have no technical support here where I live in Peru so before sending it for reparation I wanted to ask if anyone knows what could the problem be? Any help would be very appreciated. Thanks a lot! |
No one... please..
Thks!! |
No output from MBOX 2 Mini | sh3p | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 10-27-2009 07:39 PM |
mbox 2, no right channel output | destinationd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-15-2009 07:20 AM |
Left channel output louder in Mbox 1, please help. | pcmusicpro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-14-2008 09:40 AM |
Mbox Headphone Output - Only one Channel | dvottero | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-19-2006 06:40 PM |
MBox broken channel output | jes | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-13-2003 08:08 AM |
