Old 04-30-2000, 04:58 PM
midimac midimac is offline
Default Track Transfer with inserts
I am not able to do a track transfer from a PT5 session containing a track with more than 2 inserts. I have to remove inserts from that auxiliary track to keep the count at 2 maximum, then the transfer works. The error message is "not enough memory". My system is a PT Mix Plus on a G4. The resulting session contains about 25 tracks. A cure?
Marc Girard
Sono-Tele
Old 04-30-2000, 05:11 PM
Compression Records Compression Records is offline
Default Re: Track Transfer with inserts
Do you get the error while opening in PT? If that's the case, aren't you just maxed out as far as DSP availability is concerned?
Marco Marinangeli
Magelic Productions, Inc.
Compression Records
http://www.compressionrecords.com
Marco Marinangeli
Compression Records
Old 04-30-2000, 06:36 PM
Oli P Oli P is offline
I get the same error message if I have some inserts on the session I want to merge from, that are already active in the destination session. Also if an aux group has the same name as one already in the dest. session.
www.olipoulsen.com
iMac27 i9 3.6 (late 2019) / 64 GB Ram / OS 10.15.7
Apollo 8 / PT Ultimate 2020.9.1
Old 05-01-2000, 05:08 PM
<BLOCKQUOTE><font size="1" face="Arial,Helvetica,sans-serif">quote:<HR>Originally posted by Compression Records:
<HR></BLOCKQUOTE>
No I get the error message while trying to do track transfer
Old 05-01-2000, 06:01 PM
Paul Greyson Paul Greyson is offline
I believe this bug is fixed in the upcoming 5.01 release.
Paul Greyson
Digidesign Engineering
Paul Greyson
Old 05-01-2000, 06:09 PM
Are you using version 2.1 of TrackTransfer? If not, try it. If you already have it, I'd try a previous version, as unorthodox as it may sound. Also, what OS are you running? I wonder if there's some incompatibility with OS 9...
Marco Marinangeli
Compression Records
Marco Marinangeli
Compression Records
How to add more inserts into a track? papitopinillo Pro Tools 9 27 08-06-2019 04:30 PM
How do I copy inserts to another track gavriil1 Pro Tools 10 8 11-21-2012 01:15 PM
Track Fuzz wih no Inserts AlexDC Pro Tools M-Powered (Mac) 0 04-28-2010 07:41 AM
Inserts are "post" track, right? tlester Pro Tools TDM Systems (Mac) 2 02-07-2007 09:30 AM
Track Transfer won't transfer (time code problem) apetrocelli Pro Tools TDM Systems (Mac) 4 10-17-2000 01:49 AM
