Problem Solved Re:Can not Start Pro Tools
Everything was working fine when I shut down last night. I have not added or changed anything.
Here's the error I'm getting when trying to launch ProTools : " Could not complete your request because: Assertion in "Sys_FileLoc.cpp, Line 57 ." Can someone pls help remedy this [bleep] so that I can get some work done? thanks.
G5 Dual2.0 OSX 10.3.4 Digi002R PTLe 6.4? Logic 5,6,7 Reason 2.5 G4 Powerbook1.5 OSX 10.3.4 Digi MBox Ptle 6.4 |
Re: HELP PLS! Can not Start Pro Tools
Try trashing your preferences, Go to Users > “your user name” > Library > Preferences and trash DAE Prefs, DigiSetup.OSX, Pro Tools 6.x prefs, "com.digidesign.protools.plist" and "com.apple.audio.AudioMIDISetup.plist". Trash all of the Digidesign Databases folders on the root of every mounted drive. restart and run repair disk permissions on your system drive. Thanks, Digidesign Tech Support |
Also please explain where is the Run Repair Disc Permissions? thank you.
I found the Repair Disk Premissions. Thank you for your help Digitech. can you tell me what caused this problem, so that perhaps I can avoid this in the future? This cost me a session today.
Click on OS X/Pro Tools 6.x setup and general troubleshooting at the top of this Pro Tools LE for Mac forum. These suggestions and others are all there.
"Disk Utility" is in your Applications/Utilities folder, or use the Apple and F keys to find it. The "Digidesign Databases" folder is on the root of all mounted drives. You can also do a Find on all mounted drives to find those. Drag them to the trash and empty the trash.
Administrator Avid Pro Audio Community |
I did as you suggested. Still no Pro Tools launch. Same error is occuring.
please help remedy this and explain what the possible causes of this error are. thank you.
I little system info would help...
What OS version? Which Mac? How much ram? What kind of drive (internal - external)? Which Digi system? What PTLE version? Are you trying to open a specific session or just trying to launcing it by clicking on the actual PTLE icon (not an alias)? dk ------- Dual 1.25GHz FW800 / 512MB ram OS10.3.4 Panther PTLE 6.4 - DIGI 001 100GB OWC Firewire Audio HD DigTranslator 2 McDSP Analog Channel Waves 4 - Native Power Pack
www.dpksound.com |
What OS version? OSX10.3.4
Which Mac? G5 Dual 2GHz How much ram? 512 What kind of drive (internal - external)? Lacie external FW Which Digi system? 002Rack What PTLE version? 6.4 plus all recent updates: Core Audio 6.5.2 6.4cs5 I am attempting to launch the ACTUAL APP ICON in its original default location.
Try uninstalling core audio?
And make sure Classic is not running? Make sure the record drive is not set to "Journaled" (set in Disc Utility)? dk
www.dpksound.com |
thanks dk. here's the readout in Disk Utility:
Mac HD Format: Mac OS Extended (Journaled) Permissions Enabled: Yes GM Firewire (audio record drive) Format: Mac OS Extended Permissions Enabled: No Is this correct? Journaled and Permissions are OFF in the external LaCie drive. Should they be OFF on the Mac HD as well?
Quick start dialog box gone [solved] | Jswassing | Pro Tools 10 | 2 | 12-03-2012 05:29 PM |
[solved] Can't Start Pro Tools 8 LE on Win 7 64-bit | Jaliyah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 12-29-2011 02:39 PM |
(Problem Solved) Pro Tools doesn't know how long a second is anymore. | AshNicholson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-07-2009 01:25 PM |
Pro Tools delay problem-Solved! | PTL81 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-21-2007 11:51 AM |
Uninstalling Pro Tools Free on XP. Problem Solved | Zero Phoenix | Digidesign Hardware & Software | 0 | 07-08-2004 11:45 PM |
