#351
Re: Delay Compensation Bug
OMG hell just froze over ...
#352
Sweet!!
#353
__________________________________________________ _______________________________________ Intel i7-2600K @ 3.40GHz + GigaByte Z68X-UD3H-B3 + Noctua NH U12P SE2 + 32GB + EVGA GTX 950 SC+ Windows 10 Professional x64 + 4K Monitor + RME 800 StudioOne + Cubase (+ Pro Tools for simpler old stuff) |
#354
THANK YOU, AVID!
T- ----- Waterstreet Studio Main: MacPro 2012 ([email protected]), 48GB, Apple/Samsung SSDs, WD Blacks. macOS 13.3 DSP & IO : Pro Tools HDX2(2018.3), 2x UAD Octo, HDIO 16x16 Analog IO(3), HDIO 16x16 Digital IO Plugins: Avid, DMG Audio, Kush, oeksound, P'n'T, Plugin Alliance, Softube, SoundTheory, Sonnox, Sound Radix, SoundToys, UAD, VEP, etc Hardware: API, Chandler, Hardy, Moog, Neve, Shadow Hills, Smart, Summit, TC Electronic M6000, UREI, etc Microphones: Telefunken, Neumann, Shure, AKG |
#355
I just want to give a little heads up about the workaround when putting the VI on a audio track. It doesn't really work correctly because if you compare the multi-out VI´s against other audio tracks in the session it will not play in sync against the other tracks. It only plays in sync with the tracks that are in the multi-out setup, so to speak. Maybe this is working for some people and not for others. One person did test and confirm what I found though. So I just want people to be aware of this. Please see this thread for more info: http://duc.avid.com/showthread.php?t=353680 This is the thing with this issue. It is very easy to miss some step, like checking against other audio tracks. (I missed that myself... ) So if you are using this workaround, just be sure to check against other tracks in the session as well and use plugins that causes a lot of latency, to be sure that it is working. Great to finally hear from Avid about this! Best regards, Markus
Windows 10 Intel core i7 4790k, 16Gb ram MacBook Pro Retina 13" late 2013 OSX 10.12 Intel Core i5 2,4 GHz 8GB Pro Tools 2018.4 Eleven Rack + Expansion pack RME Fireface UCX |
#356
JC - enormously grateful for your presence here.
Please could you ensure that the thread below is also given a look as it appears to be linked to the delay compensation issues others are seeing, and has been reproduced independently: http://duc.avid.com/showthread.php?t=349637 Jules |
#357
The combination of the delay compensation bug and the AVE problems definitely kills PT11 for us. We see us forced to go back to PT10. We just upgraded our three HD system to HDX. This is real pain.
-Andreas |
#358
It works without being in sync with other audio tracks. I'm glad we finally have some sign of life from Avid in this thread, but I do find it interesting that we have dead silence for almost a year until I suggest publicly bringing this to everyone's attention at every Avid event. It may have nothing to do with that and be purely coincidence, but the timing does suggest Avid may not want that to happen. So, I am moving forward with publicly pointing this flaw out at every Avid event, including webinars such as this upcoming one: http://apps.avid.com/webinars/2014/E...lq_cid=1756605 and I hope others will too. The squeaky wheel does get the grease. Let's make this wheel so squeaky that they can't ignore it anymore. . |
#359
Finally we get some reply....
It's been nearly a year since PT11 was released. I have a really bad taste in my mouth. Too much, too little, too late to lie again with you Too much, too little, too late to try again with you We're in the middle of ending something that we knew It's over |
#360
We'll be merging the multiple threads here and on IdeaScale as well as creating a KB article to bring some focus to this. Thanks, JC |
major PT11 delay compensation weirdness. | frozenintime | macOS | 18 | 02-18-2015 05:38 AM |
LE delay compensation plug ins | nossnevs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-14-2007 11:57 AM |
Plug-in Delay Compensation | Nard | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 18 | 10-03-2006 05:18 PM |
Plug-In Delay Compensation | guitar131 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 10-31-2005 03:31 PM |
Plug In Delay Compensation | tj_davies | Pro Tools TDM Systems (Mac) | 7 | 09-29-2004 11:51 AM |
