Impact Side Chain
Is there anyway to use the "EXT Side Chain" on the Impact Plug-In?
Justin |
Re: Impact Side Chain
Hi Justin,
Sheldon |
Well I'm basically trying to have a bus compressor on the Main Left/Right that has a high pass filter in it so that the kick drum doesn't keep initiating all the compression. It doesn't sound as if you signal chain will for me here.
Justin |
Hi Justin,
One way to do this would be to take the top of channel direct out from the Left/Right mix, assign it to a physical output (such as the 2-track output), loop it back into an input (such as the 2-tr input), and assign this "return" input as the key source. Make sure to NOT assign the return input to Left/Right, as this will cause a feedback loop. The trick is to use the top of channel pickoff point, which will be pre-compressor. Sheldon Last edited by Sheldon Radford; 07-14-2009 at 04:58 PM. Reason: Removed incorrect routing suggestion... |
I'm really confused on how to set this up internally. Can you explain it a bit more.
Justin |
Hi Justin,
I edited my previous post because I realized I was recommending something that can't be done - it's not possible to route the Mains Direct Out to a plug-in. That said, the first suggestion using an external loopback is valid. Let's see if I can clarify how t do that...
Sheldon |
Is it possible to side-chain an EQ? | Herkimer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-03-2009 06:00 PM |
Compressor side-chain how to? | porkipine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-15-2008 09:34 AM |
How do I set up a Side Chain | junglelabs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-30-2007 10:49 PM |
Side Chain | ByPass | Tips & Tricks | 1 | 05-08-2007 12:33 PM |
A better way to side chain? | studiojb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-24-2007 04:40 PM |
