Old 09-02-2011, 01:12 AM
James Drake James Drake is offline
Default perfect mid/side encode/decode in PT?
I am trying to make a perfect mid/side encode/decode chain.
I take a normal L/R stereo track, duplicate it. On one of them put a trim plugin just to invert it.
One of them routes to my mix bus.
The other routes into the mid/side encode chain.
The mid/side signal is then on a stereo bus, which goes into the mid/side decode chain.
The mid/side decode then routes to the mix bus.
So, in theory the output of the mid/side decoder should be the same as the stereo track in the first place.
Since one of the stereo tracks is inverted, the mix bus should null.
But I can still clearly hear the programme, peaking around -35dBFS.
I have tried both the Waves mid/side matrix, and just routing in PT and the trim plugin.
Is it possible to have a perfect mid/side encode/decode chain in PT?
James.
Old 09-02-2011, 01:15 AM
Default Re: perfect mid/side encode/decode in PT?
make sure you have identical delays for all signal chains.
Old 09-02-2011, 01:36 AM
ADC is on.
Old 09-02-2011, 04:08 AM
-35dB is a rather high "left over" from something that should null. can you post a screen shot or a template session so it´s easier to verify?
Old 09-02-2011, 04:29 AM
i could, but it's pretty easy to recreate with any 2-track source i think.
maybe put up a PT session later.
the gist is that the output of a M/S endode/decode chain should be identical to the input.
but I can't get the input and output to null, pretty sure no delay funnies going on. the 'remainder' doesn't sound 'phase-ey'.
Old 09-02-2011, 04:37 AM
just to make sure ADC isn´t doing something weird:
insert a trim on the other leg(s) as well and but leave it at unity and no reverse to make sure all channels have the identical plugin delay applied.
have you tried switching ADC off/on? Any difference?
Old 09-02-2011, 04:41 AM
yeah, already tried that.
haven't tried with ADC off. but do have DSP cache off since that was really screwing my ADC until Massey helped me out! (I'm on G5).
Old 09-02-2011, 04:43 AM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
Sure you checked it already but is the panning is 100% on all tracks?
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3
MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM
MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24
Old 09-02-2011, 04:46 AM
I just did this:
Duplicate tracks with a stereo-music. Send both tracks to my stereo out.
On the first track I inserted a Soundhack MS-matrix in LR to MS mode all faders at unity.
second slot another instance same plugin but set to MS to LR. So the output of that track went through an MS matrix twice and should be identical to the original clip
On the second track I insert a multi-mono trim set to phase reverse.
When I play both tracks at same level they null completely.
Maybe somewhere in your chain a pan knob isn´t set fully L/R or something like that?
Old 09-02-2011, 04:51 AM
i try to not use pans, instead just route directly to one side of a stereo bus.
would like to try the soundhack plugin, can't find it though.....
can I use the Mbox2 side to side to an Omega Lexicon?? nastyartproduction 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-23-2010 06:46 PM
SRS Circle Surround Encode/Decode Plug LucidMJW Post - Surround - Video 3 07-29-2009 01:39 PM
Batch MS Decode/ MS Decode multiple files at once tlloren Post - Surround - Video 11 07-15-2009 12:36 AM
Monitoring 6 ch's @96Khz Encode/Decode DarthFader777 Post - Surround - Video 7 01-30-2008 08:36 PM
Digi,Side by Side errors in event viewer with PT's HD 7.4? x9blade Pro Tools TDM Systems (Win) 8 12-15-2007 11:19 AM
