Command 8 Fader Issue
I have had a recent major issue with my Command 8 rendering it useless. Regarding the faders, they almost seem to have a mind of their own.
Outline of the issue: It beings after I turn on the Command 8 and it initializes. They faders go through what I can only assume is a normal start up process of going up and down, but they never go down. The motors keep revving, and the faders keep attempting to travel upwards, even though there is nowhere to go. It gets louder as the motors grind away, and it never stops. I have tried a couple popular troubleshooting responses: -uninstalling and reinstalling the latest firmware. System info in the F1Utility says 02.01.02 -Going into Utility and recalibrating the faders. Neither has worked. This is a great control surface, but with without control of the faders for automation and leveling it is basically useless. Someone help me out here please. SYSTEM INFO: ProTools 10 M-audio FastTrack Ultra 8R SiSoftware Sandra ID Host Name : Evan-MixTop Workgroup : WORKGROUP Computer Model : HP Pavilion dv7 Notebook PC 103C_5335KV G=N L=CON B=HP S=PAV Serial Number : 2CE14***** Chassis : HP Notebook Mainboard : HP 1803 Serial Number : PCKVL2B******* BIOS : HP F.02 10/03/2011 Intel vPro : 7.01.03.1053 Total Memory : 8GB DDR3 SO-DIMM Processors Processor : Intel(R) Core(TM) i7-2670QM CPU @ 2.20GHz (4C 8T 2.8GHz/3.1GHz, 2.8GHz IMC, 4x 256kB L2, 6MB L3) Socket/Slot : FC PGA988 Chipset Memory Controller : HP Core (Sandy Bridge) Mobile DRAM Controller 100MHz, 2x 4GB DDR3 SO-DIMM 1.33GHz 128-bit, Integrated Graphics Memory Module(s) Memory Module : Samsung M471B5273DH0-CH9 4GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Samsung M471B5273DH0-CH9 4GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5) Video System Monitor/Panel : CMO Generic PnP Monitor (1600x1200, N173O6-L02 , 17.6") Monitor/Panel : Hewlett Packard HP LP2065 (1600x1200, 20.2") Video Adapter : Intel(R) HD Graphics 3000 (12CU 60SP SM5.0 650MHz/1.1GHz, 2GB DDR3 1.33GHz/1.6GHz 128-bit, Integrated Graphics) Video Adapter : Intel(R) HD Graphics 3000 (12CU 60SP SM5.0 650MHz/1.1GHz, 2GB DDR3 1.33GHz/1.6GHz 128-bit, Integrated Graphics) Graphics Processor OpenCL GP Processor : AMD Radeon HD 6700M Series (480SP 6C 725MHz, 2GB 128-bit) Compute Shader Processor : Intel(R) HD Graphics 3000 (60SP 12C 650MHz/1.1GHz, 2GB DDR3 1.33GHz/1.6GHz 128-bit, Integrated Graphics) Storage Devices Hitachi HTS547575A9E384 (750.2GB, SATA300, 2.5", 5400rpm, 8MB Cache) : 699GB (C:) (D:) hp BDDVDRW CT40N (356.1MB, SATA150, BD-R, DVD+-RW, CD-RW, SSD, 2MB Cache) : 340MB (E:) Logical Storage Devices SYSTEM : 199MB (NTFS) Hard Disk (C:) : 681GB (NTFS) @ Hitachi HTS547575A9E384 (750.2GB, SATA300, 2.5", 5400rpm, 8MB Cache) RECOVERY (D:) : 17GB (NTFS) @ Hitachi HTS547575A9E384 (750.2GB, SATA300, 2.5", 5400rpm, 8MB Cache) HP_TOOLS : 99MB (FAT32) BLENDER BOOK (E:) : 340MB (CDFS) @ hp BDDVDRW CT40N (356.1MB, SATA150, BD-R, DVD+-RW, CD-RW, SSD, 2MB Cache) Peripherals LPC Hub Controller 1 : HP HM65 LPC Controller LPC Legacy Controller 1 : Winbond W83687THF Audio Device : HP Cougar Point High Definition Audio Controller Audio Codec : Integrated Device Tech 7605 Disk Controller : HP Cougar Point Mobile 6 port SATA AHCI Controller Disk Controller : HP PCIE CardReader USB Controller 1 : HP Cougar Point USB Enhanced Host Controller #2 USB Controller 2 : HP Cougar Point USB Enhanced Host Controller #1 USB Controller 3 : HP Renesas Electronics USB 3.0 Host Controller SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : HP Photosmart 2600 series (1200x1200, USB, Colour) Printer : HP Deskjet F4200 series (1200x1200, USB, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Realtek PCIe GBE Family Controller (Ethernet) Wireless Adapter : Intel(R) Centrino(R) Wireless-N 1000 (802.11g (ERP), TKIP, 54Mbps) Power Management Battery No 1 : Hewlett-Packard 8850 98.23Wh/7.66Ah Operating System Windows System : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 5.9 |
Re: Command 8 Fader Issue
Open the Command 8 detach the faders from the motors then reattach this should solve the issue I had this once and now mine is fine :)
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
I know its probably been a while, but do you remember how you did that? I just wanna have some basic idea of what I'm doing before I go poking around inside in case I manage to damage something else.
Just unscrew the bottom plate when inside just pull the connector of the fader its really easy :)
Raoul Crane
D-Command ES + Fader Madule Fader Problems | FedericoF | ICON & C|24 | 11 | 05-24-2013 04:27 PM |
FAder Issue D-Command | kd_special | ICON & C|24 | 9 | 07-10-2010 10:30 AM |
Command 8 Fader Issue | iron_aidan | ProControl, Control|24, Command|8 | 9 | 12-06-2008 10:49 AM |
Anyone here get an 8 fader D-Command instead of a C|24? | banana boy | ICON & C|24 | 0 | 05-25-2007 06:19 AM |
'Fader Pack' and ProControl Fader order issue | Ciaran | ProControl, Control|24, Command|8 | 2 | 03-21-2005 11:58 PM |
