Re: 10.3.4 Hybrid iLok problem
I had a similar problem with Pro Tools in general when installing 10.3.4. See my thread here:
http://duc.avid.com/showthread.php?t=336429 |
If that is the case you should be able to delete (or at least remove it from your plug-ins folder) the updated version of the Hybrid plug-in. And then install the correct version for your Hybrid license from this page in the Knowledge Base: Hybrid Information and Downloads Kbase http://avid.force.com/pkb/articles/download/en355527 Not that you have to, but if you do have Hybrid v1.0-1.5, there are a couple of upgrade options to either Hybrid 1.6, or to the full Pro Tools Instrument Expansion Pack on the bottom row of this page in the Avid online store: Pro Tools Plug-Ins: Virtual Instruments |
Hi everybody here the same problem. No way to launch Hybrid since PT10.3.4 installed. Trashed preferences re-installed hybrid and ilok driver. No way. It was perfect in 10.3.3.
I don't know what I can try now.. Anyone risolved this? Best Andrea |
I posted elsewhere but I'm having no joy with this either. Trying to update to 1.5.4 throws up iLok errors despite having the latest drivers etc. Most annoying.
Drink up, dreamers... you're running dry |
1) Clean uninstall of 10.3.4 and re-installed 10.3.3. But now, as posted by others here as well, Hybrid won't work with 10.3.3 anymore. 2) Trashed the Hybrid .dmp and respective content from the Plugins-folder, as well as the DAE Prefs "installed plugins" in the User Preferences. Then tried to re-install Hybrid 1.5.2, which is the download offered under the link that Bruce posted. Problem: Hybrid 1.5.2 installer says it detects a newer version, hence it will not start installing. Funny enough, Hybrid 1.5.3 upgrader won't work either. Says, no version of Hybrid has been detected. @ Avid: This is most annoying. Please advise, how to uninstall Hybrid 1.6 so owners of a 1.5 license can install their version. - What has changed in Hybrid so much anyways, that we are supposed to shell out money again? |
#16
The same problem just showed up for me.
I have taken all the steps that the above users have posted with no luck. Avid/AIR please help us asap! iLok driver software up to date. Hybrid license is visible on iLok from iLok license manager. Pro Mac 2.26 GHz "Nehalem" 17 GB RAM Mac OS 10.6.8 PT HD3 10.3.4 192 i/o |
#17
Check this out guys. This is the key to successfully remove version 1.6, and install version 1.5.2 again, and upgrade to 1.5.3. Works perfectly. Found it in another discussion in this forum:
#18
Another Hybrid Auth Question....
I lost my ability to use Hybrid after my PT 10.3.3 to 10.3.4 update.
When starting PT get alerts telling me that I do not have the license required for Hybrid v.1.6. My iLok* account shows that a license for Hybrid is present but, there is no version number. I believe this means that it is an earlier (than 1.6) version. Q: How do I get a license for Hybrid v.1.6? Do I need to purchase Hybrid v1.6 after the update to PT v10.3.4? *My iLok drivers are up to date. ProMac 2.26 "Nehalem" 17GB RAM Mac OS 10.6.8 Pro Tools HD 5 |
#19
Re: Another Hybrid Auth Question....
You need to purchase the upgrade to Hybrid v1.6 available from the Avid store.
#20
Im stuck in a loop of already have a later version and not found in the systme when i go forward and back a version?? |
Missing iLok authorization for Pro Tools 10 | finalcut | Windows | 13 | 12-06-2013 11:50 PM |
error: missing ilok authorization for pro tools 9. please insert the necessary ilok.. | weakluv | Windows | 2 | 07-07-2011 05:47 PM |
Pro Tools HD 8 asks for authorization with iLok in? | ericsvizeny | Pro Tools TDM Systems (Mac) | 3 | 04-30-2011 09:39 AM |
missing ilok authorization for pro tools 9 | monstaro | Pro Tools 9 | 1 | 03-03-2011 02:45 AM |
