Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 06-03-2020, 03:30 PM
pelagos pelagos is offline
Default PT2020 (High Sierra) and 192 Blue + HDCore card
Hi there
(apologies for the cross post was just looking for an answer quickly!)
I am struggling to find a definitive answer but...
I can pickup a 192 I/O Blue interface and a HDcore card (pcie).
Will this work in High Sierra and will it be visible as an interface for say ProTools 2020 (or I have earlier versions as well) or any other DAW?
I have read posts that say its all fine and others that say NO WAY...
I know Pro Tool and Digidesign gear can be a bit picky about playing with other things but if someone could give me a definate YES or NO that would be great...
If the answer was YES would that mean that additional Accel and HDcore cards and 96 I/O interfaces could be connected as well?
Many Thanks
Old 06-03-2020, 03:33 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: PT2020 (High Sierra) and 192 Blue + HDCore card
No.
Only HDN and HDX will work with PT11 and later. HD cards are for PT10 and earlier
Janne
Old 06-03-2020, 03:36 PM
OK thanks
Is that PT10 HD or just normal PT10
I have read that people have had these setup and they show as normal interface that can be used by any DAW - I gues your saying that exclude ProTools (later than 10)
thanks
Old 06-03-2020, 03:37 PM
JFreak's Avatar
You will need HD software to go with HD hardware
Janne
Old 06-03-2020, 03:39 PM
JFreak's Avatar
If you install CoreAudio driver you can use it with Logic with certain limitations. But the problem still is HD cards were last supported on Snow Leopard. No way you get it working in High Sierra
Janne
Old 06-03-2020, 03:49 PM
OK thanks for the speedy answer
(apologies for the x post)
Old 06-03-2020, 03:50 PM
arche3's Avatar
arche3 arche3 is offline
192 blue still works with hdx cards under 2020.5.
Hd core cards do not work anymore in protools.
Get a hdx card and 192 blue.
Sent from my SM-G986U using Tapatalk
Old 06-06-2020, 04:53 AM
TheFilterLab TheFilterLab is offline
HDN card should work with that configuration. I'm on PT2019.10 (mac pro 5,1, OS 10.14.6) and use a HDN card with four blue interfaces. You just need the cable adapters to convert to the newer digilink connectors. The older TDM cards won't work past PT10.
Good luck,
Jared
Old 06-11-2020, 01:30 PM
Thanks for all the answers
I see the path ahead now (sort of).. With the HD native and HD X cards do they still require a 'HD" version of Pro Tools or will they run under the current standard PT versions?
many thanks again
Old 06-11-2020, 01:32 PM
JFreak's Avatar
Yes, you need HD/Ultimate software to go with HD hardware
Janne
Mbox 3 High Sierra 10.3.4 Blinking Blue Light nickthap FireWire & USB Audio Interfaces (Mac) 4 01-17-2023 04:03 PM
192 Blue + HDCore card - High Sierra and PT2020 pelagos Pro Tools TDM Systems (Mac) 1 06-03-2020 03:40 PM
MAC PRO High Sierra & PTHD 2018 can't recognized PCIe Native card Sutee Sangsareechon Pro Tools 2018 1 05-11-2019 04:48 PM
Video Card - Mac Pro High Sierra & Native Siegfried Meier Pro Tools HDX & HD Native Systems (Mac) 46 02-03-2019 02:26 PM
Question: Sierra or High Sierra for PTHD 2018.3? johnnyv Pro Tools 2018 25 03-18-2018 08:30 PM
