Track direct out
How do you create a direct output feed via a bus from a track, pre plugins and fader/mute without duplicating the track?
Re: Track direct out
If you just want to send a track straight to an output on your interface then you don't have to use a bus; put a pre-fader send on the track directly to the output. Is this what you mean? It won't be pre-inserts though... If you want a split without any processing then you'll need to bus the track output to an aux track and take the send off the audio track and put the plugins on the aux.
Hope this helps.. |
I want to have a monitor side and a mix side to be able to use automation while tracking.
Using the buses to create the mix side, but I don´t want the monitor-eq sent to the mixchannels. I want to automate eq´s therefor I can´t use the EQ on the monitorchannels. |
Direct sound in one session/no direct in another? | Balders | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-12-2009 02:05 AM |
Protools and Track Codes -Direct CD Recording | fifty8th1 | Pro Tools TDM Systems (Mac) | 1 | 02-21-2006 07:26 PM |
direct recording , line 6 or direct box? | dannypassenger | General Discussion | 3 | 01-12-2005 07:17 PM |
8 Track Direct Out Mixer??? | trackfive | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-31-2000 08:16 PM |
What's the best BASS direct box direct to PT recording | dw | Tips & Tricks | 18 | 05-13-2000 08:08 PM |
