Adjusting brightness of meters on 888?
Greetings,
Is it possible to adjust the brightness of the meters on the 888? When I first turn the unit on they are bright. It seems that when the Mac comes online, their brightness drops considerably - almost to the point where they can't be seen. All of the other lights are nice and bright. Can't seem to find anything in the manual... Thanks, Jared |
Re: Adjusting brightness of meters on 888?
Sounds like a hardware problem with the 888. Most likely a power supply problem due to overheating. They run hot, but do you have it in a situaion where it is excessively hot?
If not then I would contact your dealer or Digi. Mine has never done that. In fact those are the brightest meters in my system, all the time... George Cumbee Classic Recording, Franklin, TN www.classicrecording.com
George Cumbee, Pres. Audio Creations Inc., Paducah, KY Classic Recording, Franklin(Nashville), TN www.classicrecording.com |
Greetings,
It is an 888 - 16 bit. thanks, Jared |
Sync IO LCD Screen Brightness | Siegfried Meier | Pro Tools TDM Systems (Mac) | 3 | 04-10-2013 11:56 AM |
Laptop display brightness increases when I run Pro Tools - why? | iain_m | Windows | 10 | 06-20-2012 03:53 PM |
System 5 Brightness Utility | PhilippeCNA | System 5 | 2 | 12-23-2011 01:36 AM |
Advise on high brightness 15" monitor | digidesigner | VENUE Live Sound Systems | 1 | 06-04-2011 07:33 AM |
Lack of sparkle/brightness: mastering helps? | davetron5000 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 05-12-2004 09:41 PM |
