Pitch rise effect and loop recording at a later date
Sorry for all the threads but i need your knowledge again. I've squashed 2 questions into one.
Firstly creating a dramtic pitch bend effect. I have a signal generator with a sawtooth wave on it. I am automating the frequency from 20Hz to 2kHz. I have a gradual line (using the line tool). I notice that the pitch doesnt rise uniformly, it does up until about 1300Hz, then it seems to rise at a faster rate if that makes sense? So I am having to make the line less steep to wards the end to try and counteract this. I'm thinking maybe it should be a parabolic curve or something instead. Yet I can't draw this in. My second problem is loop recording at a later date. I have recorded a four bar part. If I want to go back to it at a later date and record the same four bar part but still keep it as part of the playlist how can I do this? Using loop record just records over the original.Is there anyway to keep the original recording. Basically I want to be able to do normal loop recording, but like over a longer period of time if that makes sense, so record take 1 on monday, take 2 on tuesday, take 3 wednesday etc, but still have them all in the same playlist. Is this possible? |
Dramatic pitch rise effect - how to?? | phillyt2k | Pro Tools 10 | 9 | 04-28-2013 11:35 AM |
ER in Tube Preamp Effect Loop | phab76 | Eleven Rack | 2 | 03-21-2011 10:47 AM |
How to do "slow pitch down" effect in PT? | emde | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 02-14-2006 01:34 PM |
Can you Effect Loop on the 002 Rack?? | Evandude | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 10-14-2005 09:34 AM |
pitch effect | dat | Pro Tools TDM Systems (Mac) | 1 | 12-31-2004 03:35 AM |
