Mixing tips?
I am attempting to mix an entire record
solely in Pro Tools. I am aware of all the fidelity issues that I face, but the band's budget ties my hands from spending a couple of weeks behind an SSL. The music falls somewhere in the British "Radiohead" type of sound. I have a G4 450 mhz w/ PT 5.0 24 mix 1 mix card and all the plugs you could want. Anyone else out there getting good results? If so, please share...... |
Re: Mixing tips?
I recently recorded and mixed an album of a band that does somewhat comparable stuff to Radiohead (sometimes; check out the samples on www.tftt.de).
I have a Mix-core and 3 vintage farms as well as some outboard fx (PCM90, PCM80, NuVerb) and was maxing out DSP on almost every song without submixing or going the audiosuite way... Peter
http://www.merlinsound.de |
Re: Mixing tips?
Run as many reverbs & ext FX that you are used to, via AES /SPDIF or even analog i/o. Dont expect world class reverbs from plug ins (althogh a new breed is just emerging that may be more than bearable ...) as they will EAT all your DSP. Running stuff live is THE way to go.
For example I run 1 x dual reverb engine FX via AES 1 x multi FX / Harmonizer FX via AES 1 x Analog 'classic' reverb via analog i/o the comps and other **** yo need dont use up much after the outboard take the strain of your set up... I mix all in PT now. Jules |
Re: Mixing tips?
You probably don't have enough DSP. In regard to the fidelity issues that you face. If you use Pro Tools right you shouldn't have any fidelity issues.
Re: Mixing tips?
this stuff is a full band.. all protools..
http://dotfash.com/music/mp3 check out the radioHead Cover "Stop Whispering" ------------------ James dotFash.com
=j= |
Re: Mixing tips?
If you can wait till ProTools 5.1 shows up you'll have access to RTAS Plugins that will run off your G4. You could load up 24 or more 4 band Ren EQs!
------------------ [email protected] <BLOCKQUOTE><font size="1" face="Arial,Helvetica,sans-serif">quote:<HR>Long Live Nubus and TI<HR></BLOCKQUOTE> |
Mixing Tips!!! | K-Stylez | Pro Tools M-Powered (Win) | 1 | 04-02-2011 05:41 AM |
Mixing Tips | brendanJacobs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 08-24-2009 09:07 AM |
Hip Hop and R/B mixing tips...... | PSI | Tips & Tricks | 4 | 11-04-2002 12:06 AM |
Mixing Tips? | eternity | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-05-2002 05:03 PM |
mixing tips? | ProTool1 | Tips & Tricks | 25 | 12-07-1999 12:04 AM |
