\"Random\" mix bus distortion issue
Here's a weird one which drove me crazy for an hour last night:
While mixing a song, I've noticed a short distortion (about half a second) happening just once during one syllable of a chorus which is played/sung 5 times in total. Ok, so let's check for the obvious: - soloed every track - each track sounds fine alone, so it's not on a track - no channel, bus or master fader is overloading. The peaks are around max. -5dB during that syllable. There are higher peaks elsewhere in the song. - checked and disabled all plugins - distortion still here, no overloads - lowered the volume of all channel faders by 3dB... distortion still here, sounds exactly the same as before, just 3dB lower in volume *argh* - started soloing combinations of tracks and bingo - it's the combination of the two lead vocalists! Again, each vocalist soloed sounds fine, and the same syllable appears several times elsewhere in the song sounding fine with very similar gain. So I basically could copy & paste that syllable from the previous chorus. However I've ended up with a volume automation of the less audible vocalist in that part: A short -4dB dip did the trick, the correction is not audible in the mix. But still - what happened here? Is this some random "nagware" feature of PT LE telling me "Buy a HD rig?"
Mac mini 2018, i7 3.2 GHz, 32G RAM, 1TB SSD Mojave 10.14.6, PT 2020.5 Vanilla, several Waves V13 and some Massey plugins PreSonus Quantum, Avid S1 & Control, MC Transport, Tascam HS-P82 Field Recorder |
Re: \"Random\" mix bus distortion issue
bump...
Random Mic Input Distortion | mrtemmtation | macOS | 1 | 07-09-2013 04:39 PM |
Random distortion | AdamPT8 | macOS | 4 | 02-15-2011 02:29 PM |
For anyone who is having the random white noise burst / random distortion problem | Philly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-23-2010 04:56 AM |
PT8 + ProjectMix... RANDOM distortion! this is a bizaar issue... | rickenplayer | Pro Tools M-Powered (Win) | 4 | 01-21-2009 11:39 AM |
Random DISTORTION!!!!!!! | Musicb4hw | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-21-2007 06:16 AM |
