Old 06-06-2001, 08:57 PM
NoviceDollars NoviceDollars is offline
Default What\'s the deal with Power Supplies?
When some of you refer to 'power supplies' are you talking about battery-backups? I'm not familiar with what power supplies are, though it sounds very simple and common-sensical. Regardless, I ask you for a brief explanation.
Is a 'power supply' necessary for PTLE and Digi001, or can't I just plug everything into my surge protector?
[This message has been edited by NoviceDollars (edited June 06, 2001).]
Sean
Cost of Living
Old 06-06-2001, 09:10 PM
znelson znelson is offline
Default Re: What\'s the deal with Power Supplies?
They're talking about the power supply built into the case that powers your computer.
Old 06-06-2001, 09:40 PM
AHhhh....I see the light.
So how can I check to find out what my power supply is?
Sean
Cost of Living
Old 06-07-2001, 06:59 AM
electrobank electrobank is offline
Your power supply will have a sticker somewhere on it. Either the back by the fan, or on the side. Each power supply should have this info as it is required to have a UL Listing and provide you with power specs. Most common on computers is a 250 Watts power supply. With todays faster Bus and processor speeds, the demand for more power has increased.
electrobank
2+2=5
Old 06-07-2001, 08:07 AM
Since we're on the topic of power supplies.. any of you guys running an athlon 1.x on an A7M266? If so, what wattage power supply are you using? I've got a 300W .. I hope that's more than enough. I'm only running a 1.33Ghz cpu, 1 ide system drive, 2 scsi data drives, and a cdrw drive.
I'd also be interested in any setup tips you have for the A7M266.. mine arrives monday.. it'll be the 3rd motherboard I'm trying.
Old 06-07-2001, 02:27 PM
For anything above a 1ghz should atleat have a 300 to 350 Watt Power supply. You want consistant voltage and power sent to your MOBO at all time. Even bad power supplies are to blame for freezes and hangs.
electrobank
2+2=5
Redundant Power Supplies Kenmillerjr VENUE Live Sound Systems 3 12-19-2011 12:25 PM
Uninterrupted Power Supplies word_play 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 03-14-2010 03:02 PM
Redundant Power Supplies craig-tx VENUE Live Sound Systems 12 03-30-2009 07:15 AM
A wee question about power supplies K.B. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 05-03-2004 01:49 AM
Power Supplies toadiesXJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-18-2002 07:09 AM
