Old 07-27-2005, 07:02 AM
Xone Xone is offline
Default vocals tips and techniques
I have a mxl mogami mic that runs on a 69 volt power supply. Do I need preamps or anything else with it. I am just starting my studio and everything sounds good except vocals. Any tips or techniques are very welcomed. Anyone know how to get the airy whispers from breathing out? HELP..........
Old 07-27-2005, 06:26 PM
s.d. finley s.d. finley is offline
Default Re: vocals tips and techniques
You need to tell us MORE... which interface are you using? Does that MXL have its own power supply? If yes, DO NOT use phantom power otherwise you WILL kill your mic. I use a 001, but skip the built in pres, digital clock and converters...find a channel strip type preamp w/ spdif outs. This will make a big difference in vocals.
rock
sdf
sdf
sugarhillstudios.com
Old 07-27-2005, 06:31 PM
PsyCoNo PsyCoNo is offline
You do need a preamp with a mic... if you have an 002 or such it should have one?!
Old 08-04-2005, 03:37 AM
L.Ninio L.Ninio is offline
Yea. Stop making airy whispers.
Old 08-05-2005, 08:39 AM
rockrev rockrev is offline
If you edit out the breathing you will end up with a very strange souding vocal track. Humans breathe when we sing - it's a requirement. Listen to a killer vocal performance . . . listen real close . . . you will hear the breathing.
"Noise" isn't always a bad thing - it adds a sense of reality. Be real careful when trying to gate everything out - you may suck the life out of it.
rockrev
End world poverty: ONE
Old 08-05-2005, 08:05 PM
If you are referring to the MXL V69 mic, it has its own power supply and special 7 pin cable to attach the mic. A standard 3 pin XLR cable connects the power supply to your mic pre. It isn't a 69volt supply(actually higher voltage). I highly recommend using a pop screen (black nylon fabric style) in front of it. Also make sure you are singing into the front as its an easy mistake. When used correctly, its a great sounding vocal mic.
Old 08-06-2005, 11:49 AM
groovilator groovilator is offline
rockrev
Absolutely right. Even when I'm editing comped vocal tracks, I always make sure the breath sounds match if I'm, say, splicing a single phrase together from different takes. Hell, I might even specifically choose a particular breath sound from a particular take because it just sounds good in the context.
Nobody told me there'd be days like these .. .. .. strange days indeed .. .. ..
Old 08-06-2005, 03:49 PM
The only time i edit out breathes if there are overdubs, lets say 3 tracks, all w/ breathes at the same time, i might edit out 2 and leave one. I mainly do this w/ my larger than life clients, big guys breathe big time....
rock
sdf
sdf
stereo mic techniques for vocals davidlustrup General Discussion 11 09-04-2011 07:47 AM
the best editing techniques for vocals kyongilxp Tips & Tricks 4 10-31-2010 04:57 PM
I came here looking for Tips & Techniques... homerg Tips & Tricks 4 02-14-2003 06:46 AM
best of DUC tips & techniques NY909 Tips & Tricks 0 11-25-2002 04:29 PM
Pro Tools Tips and Techniques Phil O'Keefe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-02-2002 12:30 AM
