If I set my Mac output to 'Digidesign', ProTools can't grab the hardware when I launch. 'Hardware not installed or in use by another application' WHY?
![]() G4/500 PT24Mix Mac OS 9.04 Thanks, Simon. |
I have the same problem on my new G4 466mhz with 512mb or ram, with Mixplus, Atto Card, and Miro DC30+ Is there a fix for this? My only solution is to reboot the computer!
Remote access is the problem in my system. Everything is fine until I connect to the internet, after that I have to either switch to soundmanager in sound c.panel, or reinstall the system.
I think this is a known thing. G4 9.02 ------------------ Ben Jenssen Honskogen Studio
Life-long audio enthusiast and small studio owner. Retired. Mac Mini 2018, six core i5 3.0 gHz, 32 gb RAM. Focusrite Scarlett 2i2 3rd gen, Dynaudio BM6's, Command 8 and iPad w/Avid Control. Pro Tools 2020.11, Mac OS 10.15.7. |
I had this happen once. (9600/250 5.0.1 OS 9.0). I occasionally switch the Mac output to Digidesign with no problem, but usually switch it back before I shut down. A while back I left it set that way at shutdown. After restarting, Protools gave me that error, even after I switched the Mac sound back to internal...had to reboot.
Haven't tried to see if I can reproduce it. Tom ------------------ http://www.digitalaudiorock.com The Protools Plugin Preset Co-op |
Sounds perfectly right to me....
If Sound Manager is using your Digidesign interface, it's not available for DAE. DAE isn't a multitasking environment. Same problem if you use Peak or any other program that has a direct connection to the Digi hardware... |
Yes...but when I ran into this, even after closing all other apps and switching the sound back to internal, it thought it was in use and required a reboot. That doesn't sound right.
Tom |
Looking for DIgidesign Control Panel version 1.4.1 | franckboutet | Digidesign Hardware & Software | 4 | 03-19-2004 11:24 AM |
Digidesign Control Panel...N/W on G3 | LesPaul666 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-05-2001 07:44 AM |
Possible Digidesign Control Panel Conflicts? | RobbaDobba | Pro Tools TDM Systems (Mac) | 4 | 10-10-2000 09:24 AM |
Digidesign Control Panel ... | TCL | Tips & Tricks | 1 | 07-12-2000 08:25 AM |
Digidesign Sound Control Panel | Kenshiro | Pro Tools TDM Systems (Mac) | 4 | 07-07-2000 01:41 PM |
