submixes
I'm trying to figure out how to submix a part of a session (bouncing to disk) without having all the session going on the disk. This is to be able to free up some audio tracks .
Thanks !! |
Re: submixes
Just mute all the tracks that you don't want in the submix, maximise your levels so you use as much dynamic range as is available, and then bounce to disk. Then 'make track inactive' on the tracks you just bounced and deselect them from the track view, un mute the tracks you weren't bouncing, and then 'import audio to track(s)' the bounced wav file into a fresh stereo track. Done.
Cheers JD G5 iMac 20" 1.8GHz 1GB 160GB / Lacie FW80GB OSX 10.3.5 / MBox / PTLE 6.7 |
Re: submixes
the easiest way is to solo the tracks you need to submix. this will isolate them from the rest of the mix.
Re: submixes
Thanks , but will it bounce the length of the desire selection with out bouncing the length of the actual session
Re: submixes
When you say part of the session, are you reffering to only wanting some of the tracks or only wanting a certain part of the song (like from 1:50 min to 2:30 min or something)? If you want to do away with some of the tracks the suggestions above will work fine. If you want a certain time span of the song I would just highlight the section you want (like you would do if you were going to loop playback or something) and copy and paste it into a new session. Or similarly, delete what you don't want and save the session as a different name.
Barry |
Re: submixes
Bazzle |
Re: submixes
Submixes for final mixdown | HB1978 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-27-2008 08:53 AM |
Matrix submixes | rgr | VENUE Live Sound Systems | 1 | 12-20-2006 10:46 PM |
Master Faders for submixes instead of Auxes??? | Doogz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-24-2004 02:41 AM |
Setting submixes and levels | mysticmusing | Pro Tools TDM Systems (Mac) | 11 | 12-30-2003 05:49 PM |
Compressing Drum Submixes | dirktones | Tips & Tricks | 38 | 08-16-2002 09:20 PM |
