Old 08-19-2011, 01:05 PM
animalchinster animalchinster is offline
Default 9.0.5 won't start up on OS X Lion
When I try to run Pro Tools 9.0.5, it always crashed when it gets to loading XPand!.dpm. Anyone have a clue why?
I have an iMac 3.4 GHz Intel Core i7 processor and 16 GB of RAM, and I'm running OS X Lion (10.7.1)
Old 08-19-2011, 03:30 PM
SessionKat SessionKat is offline
Default Re: 9.0.5 won't start up on OS X Lion
Post the crash log?
-tv
Tim vdB
Avid Audio
"There's a fine line between stupid and clever."
Old 08-20-2011, 08:56 AM
Park Seward's Avatar
Park Seward Park Seward is offline
What version of Xpand! are you running? Seems 1.0.3 is the current.
http://www.avid.com/US/products/Xpand
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 08-20-2011, 09:38 PM
GuitarTone GuitarTone is offline
I'm having the exact same problem. I updated to 9.0.5. and installed Lion, everything worked fine. I then updated to 10.7.1, everything still worked fine and even finished a mastering session using it. This morning, turn on the computer and pro tools won't fire up. It hangs on whatever is the last plug-in to be loaded. I tried to post the error log but this forum is limited to 20,000 characters. Any clues is much appreciated!
Old 08-20-2011, 10:04 PM
I actually just fixed it, here's how. I went into Time Machine and restored back to before I put 9.0.5 on, then reinstalled 9.0.5 and now it works again. For how long? who knows! I'll keep you posted.
Old 08-21-2011, 11:03 AM
Make sure all your plug ins are up to date.
The Plug-in Compatibility Grid at the top of this page may be of some help.
Park
Old 08-21-2011, 01:52 PM
Franco1967 Franco1967 is offline
No, but as always uninstall Pro Tools, then install 9.0.0 anew and after that directly 9.0.5. I guess that you migrated the system with Pro Tools from SL to Lion. That makes problems.
Old 08-21-2011, 02:08 PM
necjamc necjamc is offline
Default
There is a 9.0.5 full installer for Mac so there is no need to install 9.0
- Sent from my iPhone using Tapatalk
Old 08-21-2011, 05:56 PM
I did a re-install and it seems to be working now. Thanks for the help!
Old 09-19-2011, 08:08 AM
supersean579 supersean579 is offline
It seems to be an issue with the Audio MIDI Setup. The best course of action is:
Uninstall Pro Tools
Open the Audio MIDI Setup and make sure the Pro Tools Aggregate I/O has been deleted. If it hasn't do so manually.
Reinstall Pro Tools 9.0.5
Everything should work normally from that point on.
Impossible to start Pro Tools on MacPro after downgrade Mountain Lion back to LION DESVED Pro Tools HDX & HD Native Systems (Mac) 2 05-21-2013 03:18 PM
Would you go from Snow Leopard to Lion (not Mountain Lion) if you could? EricWillhelm macOS 9 01-11-2013 10:55 AM
Downgrade from Mountain Lion to Lion The golfer macOS 7 11-14-2012 05:53 AM
PT10, OSX Lion, very slow start up, 003 not talking vaein macOS 7 06-08-2012 12:50 PM
Lion Pro Tools SE won't start on one account, but start on another AndrewGalas Pro Tools SE and Essential (Mac) 2 12-15-2011 11:06 AM
