Bounce to Move of a Edited Video Sequence doesn't work
Hi there,
we have following Problem: We have a video Sequence in ProTools wich we have edited in Pro Tools a couple times with imported .mov Files. We now want to bounce this edited sequence to a mov file, but it doesn't seem to work. Is this issue known / are there workarounds? Thanks in andvance for every1 that wants to help smashbob |
Re: Bounce to Move of a Edited Video Sequence doesn't work
Sure and sorry!
Pro Tools 12.5, Windows 10 16 GB RAM, i7, any more Info needet? |
We can assume you are using HD? Seeing that you have multiple videos in your session. I imagine all the videos are on one video track? All videos are the same format/codec/frame rate? Are you trying an offline bounce? Or have you tried online as well?
Mixed Resolution, multiple Videos, all on one track, different format/codec. Same Framerate. Havent tried an online bounce yet.
My guess is that the videos being different resolutions and different codecs is probably it.
One thing to possibly try... When you bounce, are you selecting the option to make it a specific codec? Or are you leaving the "Same as Source" box checked? Forcing it to export at a specific format may help, but I couldn't guarantee that. Your best bet would be to take the source videos, and export/convert them to all be the same resolution, format and codec and then use those files in your session. |
Offline bounce doesn't work? | luke88 | Pro Tools HDX & HD Native Systems (Mac) | 2 | 01-14-2017 07:31 PM |
Playback doesn't work after bounce to disk | Rothrock | macOS | 7 | 02-05-2013 12:58 PM |
Import Vidéo doesn't work on PT 7.4 | caron | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-14-2008 01:28 AM |
Bounce To Disk doesn't seem to work as planned | kittonian | Pro Tools TDM Systems (Mac) | 5 | 08-17-2006 05:39 PM |
Bounce doesn't work when use Automation: Why? | Tom Harmon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-24-2001 07:35 AM |
