Old 01-30-2013, 04:04 PM
noahbalboa noahbalboa is offline
Default Using ProTools with No Interface [solved]
I just got ProTools HD10, haven't tried to really record any music, I've just been playing around with it to try to get the hang of it. So far I've figured out how to record into ProTools just using the mic on my computer, but when play it back I can't get any sound to come out of either my computer speakers or headphones. I originally searched the forums to see what the problem was, but it seems like everything I'm reading says you need an audio interface to even listen back to what you've recorded. Is it even possible to just plug headphones straight into my computer and listen back? Or do I have to have an interface?
Also the output is on its default settings, and the playback engine is set to ASIO4ALL.
Old 01-30-2013, 05:05 PM
Default Re: Using ProTools with No Interface
Open the ASIO4ALL setup and choose your computer headphone out . Since you have input, that SHOULD take care of it. The info is a tad misleading. You can't run Pro Tools with nothing, unless you like working by sight. You need some kind of audio path for input and playback. Pro tools requires an ASIO compliant "device", which your on-board sound may cover. As always, using a higher-quality interface will yield better results. What you are doing, assuming you can get playback working, is fine for "learning the ropes', but at some point, you will want some kind of interface with 1 or 2 mic inputs, and decent(pro) output capable of delivering quality sound to a pair of studio monitors. From my reading here, I would look at the Focusrite boxes as being the best value(and I would not recommend the M-Audio options)
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C
I started in this business with nothing..........and I have most of it left
Old 01-30-2013, 06:58 PM
So would I go to the settings for the Playback Engine or the I/O Setup? On the Playback Engine setup I don't see any option to select an output. Under I/O Setup my only option is SpdifOut 1-2, and I can pick Stereo, Mono Left or Mono Right.
I guess based on what you're saying my problem is really finding where my headphones are under the Output options, not selecting an Output.
Thanks for your help.
Old 01-30-2013, 09:11 PM
So in Pro Tools, the audio engine is showing as ASIO4ALL? If your SPDIF output is showing available, you could use that to an external converter(old DAT machine?). Hard to say for me as I didn't have as much luck as you have already Maybe if you go to the audio settings in Windows, you can select the headphone out as default there(and hope it allows ASIO4ALL to select it too).
Old 01-30-2013, 09:54 PM
I'm just not understanding why ProTools won't recognize either my computer's speakers or the headphones as output options automatically. It seems unnecessarily complicated
Old 01-30-2013, 10:11 PM
Woohoo, got it! So the problem was just my stupidity, I had set Protools' output device to SPDIF but not my computer's. Thanks for your help man
Alessis Multimix8usbfx interface and Mbox 2 interface with Protools 11 Majorpain7 Pro Tools 11 0 01-06-2014 08:40 PM
11R as interface...some issues I'd hope to get solved Oli P Eleven Rack 8 03-30-2013 05:34 PM
Interface/Playback Engine Problem [solved] Mechanix2 Windows 2 08-16-2012 08:22 PM
Focusrite interface asio error solved. Obe1 Windows 4 01-07-2012 10:53 AM
The midi-problem = solved with an interface? Nanok 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-03-2000 06:02 PM
