Old 11-05-2020, 06:20 AM
Bob Katz Bob Katz is offline
Default Unworkable bug. Pan pots periodically get unset...
I’ve had to abandon using both Avid S1 controllers!!!!!!
At unpredictable moments pro tools will move SOME PAN pots to the middle. Usually it’s the left hand pan pot of a stereo pair while the right hand pan pot remains panned right. But also some mono pan pots also jump to center.
There’s no rhyme or reason. It just happens. And ONLY if one or both of my S1s are engaged in the Eucon control app.
This is very frustrating. It’s happened to two separate independent engineers who work here. In both cases we have to disconnect the surfaces in their app and the problem goes away. Don’t ask me how I figured out this is S1-related. It was a process of deduction.
I’ve done the usual: trashed PT Prefs at some point but did not trash S1 Prefs as I don’t know where they are.
Running Mojave on a 12 core cylinder. HELP, please. We can’t just mix with a mouse guys.
Old 11-07-2020, 06:05 AM
Norad155 Norad155 is offline
Default Re: Unworkable bug. Pan pots periodically get unset...
Is it the old "encoder #4 randomly writes automation" hardware defect?
IMDB
Old 11-07-2020, 08:04 AM
What version of Pro Tools?
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 11-07-2020, 08:38 AM
Sure sounds like it could be! And on two different S1s. I know because I removed one from Eucontrol and still got this Issue. What was the resolution of that controller bug?
Old 11-07-2020, 08:40 AM
Hi, Rich. PT Ultimate 2020.9.1
Old 11-07-2020, 08:58 AM
That's a serious bummer - I saw this happen a few times on a version or two of 12, but haven't seen it anytime recently. At that time I got in the habit of writing a break point for all the pans at the beginning of the session just in case - but it didn't have anything to do with Eucon. This sounds more serious - hoping Avid comments on this!
Old 11-08-2020, 07:08 AM
MCorbin's Avatar
MCorbin MCorbin is offline
Bob
Please open up a case and let me know what it is so we can address it properly.
https://avid.secure.force.com/pkb/ar...-Case-Creation
Thanks, and hope you are well!
Mark
Mark Corbin
Sr Principal Product Manager
Professional Audio Systems
For immediate assistance:
Pro Tools & Eucon Surfaces - +1 888-456-3444
Venue Support - +1 978-275-2557
Find out how to create, manage, and edit cases online now HERE
It's fast, easy, and effective!
Old 11-08-2020, 10:10 AM
Thank you, Mark. I appreciate your quick response. Yes, I am well, knock on wood. I think you are asking for my case number? It's 04052574
Take care,
Bob
Originally Posted by MCorbin View Post
Bob
Mark
Old 11-09-2020, 03:44 AM
MCorbin's Avatar
Yep, that's it... thanks Bob! We'll reach out via the case...
Mark Corbin
Old 11-09-2020, 07:57 AM
Mark, if Avid can confirm and finds the particular use-case can you please post here so we all know about it?
Thank you!
rich
Missing delay compensation for side chains - is it unworkable? shyko76 Pro Tools 2018 24 06-24-2021 12:01 PM
Constant CPU Errors Making Sessions Slow and Unworkable alanbenj Pro Tools 2018 10 04-25-2019 08:58 AM
mp4 unworkable in Pro Tools DAPianist macOS 10 07-06-2013 08:47 AM
Calibrating Trim Pots, Pots not responding D-Street Pro Tools TDM Systems (Mac) 9 09-04-2010 10:01 AM
Pro Tools 8 LE Slows down unworkable state every 5-10mins ThaRemedy General Discussion 5 07-03-2009 05:30 AM
