Hi All,
I'm having an issue working with VIs in Pro Tools 12.5.2 (non-HD, running on OS X El Capitan 10.11.6, maybe someone can advise. When working with virtual instruments (and other plugins) I often use the control-option-command-click shortcut to enable automation for all parameters so, for example, I can easily use the XY pads in Zebra2. However lately (and I do think this is a new issue) when I copy a MIDI clip from a Zebra2 instrument track where I have automation enabled to a different Zebra2 track where automation isn't enabled, Pro Tools gives me a pop-up dialog asking if I want to enable automation on the new track for the enabled parameters on the track from which I'm copying the clip. The options are only 'yes' or 'no' and there is no way to escape from the dialogue, which means I either have to sit there and click the mouse 200 times to tell it whether to enable each parameter or not or else force quit my session. The work around is the only enable automation for the parameters I want to use so that when I copy I clip I only have to so yes or no to a few parameters. Not the end of the world but also defeats the ease of enable all and throwing the track into touch or latch and recording some automation. It would be great if there's a way to turn off this dialog box but so far I haven't found one. Am I missing something obvious? Thanks so much. |
I've just recently enabled Plug-In Controls Default to Auto-Enabled in the preferences (mixing tab). That's one way.
Doesn't Option+clicking work as a "do to all" command in this scenario?
Yes and yes. Didn't realize the option-click thing work in pop-up dialogs. Thanks Stig!
You're welcome. Glad to help.
Copying from Clip List window to track | petesteen | macOS | 0 | 06-28-2012 11:34 AM |
Copying Track Automation to Sends. | philip888 | macOS | 0 | 01-05-2012 02:14 AM |
Copying track volume automation to send? | wheresmyfroggy | Post - Surround - Video | 3 | 06-14-2010 02:54 AM |
VCA track automation copying bug | GeneOuse | Pro Tools TDM Systems (Win) | 0 | 04-09-2008 03:55 AM |
Copying track automation in one shot | marcelloz | Pro Tools TDM Systems (Mac) | 4 | 10-26-2001 05:52 PM |
