Old 08-11-2010, 08:05 AM
Hanswurstlsepp Hanswurstlsepp is offline
Question How to suspend a specific automation parameter ?
is it possible to suspend automation of a specific parameter (e.g. volume) using D-Command ?
So what I mean exactly is the equivelant method using PT-SW by cmd/click in an automation track lane.
I searched the manual (D-Command Guide Version 8.0 - donno if there's a newer one ??? ) but I could only find an explanation how to completely suspend all automations using the dedicated Automation Suspend switch (which is pretty obvious anyway )
Cheers, STeff
MacPro5,1 , 32 Gig Ram, 2xATI Radeon HD 5770, OSX10.13.2  Pro Tools|HDX Ultimate 2018.4.0  HD I/O&192Digital&96&96i I/Os  D-Command ES  4xUnitor8 & 2xAMT8
Old 08-11-2010, 11:45 AM
diegogat diegogat is offline
Default Re: How to suspend a specific automation parameter ?
I'm not sure why you want to suspend just volume but one way would be to enter Preview mode and hold the fader. It will stay at that level while all other automated parameters keep moving. It will work with any parameter, not just volume.
Hope it helps.
Diego
Old 08-11-2010, 02:19 PM
Hope it helps.
Diego
Well, volume was just an example. It's getting more interesting while writing PlugIn automation. Sometimes it makes sense to me to bypass a certain parameter's automation while writing to other parameter(s).
So what I do usually, I cmd/click in the parameter's track lane and it is bypassed.
I was just thinking, that this should also be possible using a D-Command or another CS.
I will check out the preview workaround though - thx for the tip :)
Cheers, STeff
Old 08-11-2010, 02:33 PM
Drew Mazurek's Avatar
Preview is no "workaround".
It's the way it's done now!!!! It was created just for what you're trying to do.
You're thinking pre version 7.2.
www.drewmazurek.com
Old 08-11-2010, 03:07 PM
HI,
sorry guys - absolutely my fault. Preview is exactly what I asked for.
For some reason I wasn't aware that I can touch a parameter at the CS while PT is stopped in preview mode and that it will bypass the automation reading if a fader/knob is touched.
Shame on me - I will re-read the chapter and check out Brent's blog & groove3 for tutorial videos.
Thx a lot for the input - I'm still pretty new to PT & Icon
Cheers, STeff
Old 08-11-2010, 03:51 PM
It feels good to find a new great way to do something!!! Enjoy.
www.drewmazurek.com
Old 08-13-2010, 08:32 PM
uno1234 uno1234 is offline
Originally Posted by Hanswurstlsepp View Post
There should be a way to do this. Preview is not the answer. Sometimes you would like nothing to do with MUTE automation. You want to disable Pro Tools from playing it back. Preview is severely limited by the simple fact that it's state does not SAVE.
win7 suspend automation bug 10.3.7 studiosus Windows 10 07-17-2014 03:44 PM
Suspend Trim automation Bart HLH Pro Tools TDM Systems (Mac) 1 11-16-2012 04:15 PM
Use of Suspend Automation ramu745 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-15-2009 08:18 AM
Shortcut/keystroke for automation suspend? Floydio Pro Tools TDM Systems (Mac) 0 09-09-2008 03:24 PM
Suspend Automation Playback for some but not all Don Geppert Pro Tools TDM Systems (Mac) 3 02-16-2006 04:31 PM
