Re: Pro Tools 8 Power Mac G5...WTF???
Pro Tools Plug-In Compatibility Grid Have you done any of the steps in the General Troubleshooting thread? |
Thanks for getting back to me. I have verified and updated all my plug-ins to be compatible with 8 from the compatibility chart prior to using PT8 and double checked again. Error numbers are 9128 & 6086. I read the Tech support General Trouble Shooting info after I had posted my thread and did try most of the trouble shooting listed except testing ram and clean install which is what I will do next and see if things go better starting over. I also plan on setting up a separate partition for Pro-Tools once I've backed everything up. It will be a few days before I can get started on this and will post my progress as soon as I've done everything possible. Any other suggestions are most welcome and I appreciate you taking the time.
Just read a post from a member called "nean" who mentioned doing a safe un-install of 7.4 then 8 on top and has no problems. I upgraded to 8 from the Digi Design website and don't recall being instructed to un-install 7.4. Was I supposed to un-install 7.4 before upgrading to 8? I'm thinking of un-installing 8, going back to 7.4 and then un-installing that, then upgrading again to 8. Is it worth my time to try that? Any help is greatly appreciated. I'm quite sure 8 is a nice improvement over 7 and look forward to using it smoothly. Thanks in advance for any help.
*facepalm* it is specifically mentioned that a safe uninstall is essential. It's all over the upgrade threads here too.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D --- iCON Photography |
#16
Also, from your previous post, what did you mean by giving Pro Tools it's own partition? You shouldn't install Pro Tools to anywhere other than the drive with the OS and you should have a separate drive to record and play back your sessions from, so there's no situation I can think of that a partition would be necessary. |
#17
Some of that was added after we started seeing issues cropping up with early adopters, plus I don't think it's specified in the installation guides that an uninstall is necessary (except on Windows - where it's required..!).
#18
Again, you're absolutely sure you've done all the general troubleshooting? Especially important - making sure you do not have firewire networking enabled, especially if you're using a firewire interface or drives. A clean install of the OS and of Pro Tools 8 (not upgrading with a previous OS or PT version installed) also seems to clear up many issues for a lot of customers (this mainly for others reading this thread). If you like, we could try an iChat remote session where I could take a direct look at your system and see if I can find anything that could be causing the problems. If you're interested, contact me at vi [at] digidesign [dot] com and we can try to make arrangements. |
#19
I was thinking of partitioning my OS drive with a partition for Pro-Tools and I always use a separate drive for record and playback. My OS drive has all the applications that come with the OS as well as documents, music, downloads, ect. I've read about the benefits of partitioning and figured logically it might help with the cpu usage when running Pro-Tools for it to have it's own space on the drive. Am I way off base? Thank you Tech support for your response and also thanks to Infiniteloop for yours as well. I do think I will try the safe un-install as I remember doing that when I upgraded to PT7 from 6 because I did have problems the first time I upgraded and did not un-install 6. I'll keep you posted as to the result of that when I give it a try. Thanks again for all the help..much appreciated.
#20
You should never install an application to anywhere other than your main OS drive. There is no need to partition it and it's definitely problematic if you install the application to a different partition than your OS. Partitioning used to be more important - it's not so much these days unless you're using huge (1TB+) drives and then only if all the data you're accessing is on the same partition. This is ONLY useful for audio/video drives - partitioning the OS drive isn't necessary, nor does it help (unless, of course, you've got a specific need to partition, like you want a partition on your OS drive for specific data). |
Pro Tools on Macbook Pro, enough power? | nerwrak | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 08-31-2009 05:56 AM |
Pro Tools 8, CPU Power issues | Quintrel | Pro Tools M-Powered (Win) | 1 | 08-05-2009 06:33 AM |
Mod Delay Help Pro Tools 7.3 HD Power PC | pony | Pro Tools TDM Systems (Mac) | 0 | 01-06-2007 09:38 AM |
Pro Tools 6.2.2 for Panther and Power Mac G5 | Avid | General | 0 | 11-20-2003 06:27 PM |
The Pro Tools HD Power | Samuelsson | Pro Tools TDM Systems (Mac) | 20 | 03-30-2002 12:40 AM |
