5.1 bouncing to interleaved .wav
If I bounce to disk as an interleaved .wav(5.1) the order of the channels is always L C R Ls Rs LFE.
Is there any way to bounce as L R C LFE Ls Rs (Smpte) interleaved? I've been asked to deliver content like this and I can't see how to do it. Makes no difference how I configure the I/O setup...(Apparently Nuendo can do this? ) |
Re: 5.1 bouncing to interleaved .wav
Move the tracks around?
did you change your "5.1 default path order" in the i/o setup?
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
Thanks for the replies chaps:
The "5.1 default path order" affects what happens with the little pencil when drawing out a new path - not what you're getting from the master fader. The master fader metering is always L C R Ls Rs LFE regardless of your I/O configuration - and that's what you get in your interleaved .wav I can't believe i'm the only person who's ever needed to do this! Time for a feature request... |
Can i stay interleaved? | Nathan Schock | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-23-2008 04:20 PM |
96K 5.1 interleaved .wav problem | TNagle | Post - Surround - Video | 4 | 06-07-2007 09:27 AM |
interleaved tracks ... if and when ? | john1192 | Pro Tools TDM Systems (Mac) | 0 | 07-23-2006 03:04 PM |
SD2 interleaved and Jam | polyorchid | Pro Tools TDM Systems (Mac) | 2 | 07-12-2001 04:45 AM |
interleaved stereo--what is this | norie | Tips & Tricks | 5 | 03-21-2000 08:28 AM |
