Old 10-05-2016, 02:03 PM
realizment realizment is offline
Default Best way to create mono tracks?
I was sent a session to mix and all the wavs are stereo files, everything all the vocals and every instrument?
Would you make the drums and vocals mono before mixing?
If so what is the best way, and what about the tracks that have a little pan information?
Thanks
Old 10-05-2016, 05:09 PM
sw rec sw rec is online now
Default Re: Best way to create mono tracks?
Make 2 mono tracks and drag your stereo track down to the 2 mono tracks. Pan 'em both center. But watch that this doesn't cause any phase cancellation.
Mono vocal yes. There's no reason to have a stereo vocal track, and you can actually just use one channel on a mono track. Mono drums, absolutely not. I'll usually put the kick and snare in the middle but pan everything else to give it some dimension.
Old 10-05-2016, 05:22 PM
Thank you, yea I dont mean have the the drums mono in mix, i mean make them mono tracks and not stereo.. when i move the tracks to 2 mono tracks should i remove one then?
Old 10-05-2016, 05:32 PM
Yep. Unless you're going to l-r pan them and process each track differently for a stereo effect.
Old 10-05-2016, 05:38 PM
cool thx!
Old 10-05-2016, 11:46 PM
Stig Eliassen's Avatar
1 Select the multichannel track.
2 Choose Track > Split Into Mono. You can also right-click selected track(s) and choose Split Into Mono.
Old 10-06-2016, 12:57 PM
DJ Hellfire DJ Hellfire is offline
Always before splitting to mono, make sure that the audio isn't actually stereo. The simple way to do this is to visually compare the left and right waveform. If they are identical, then it is most likely a mono sound that was summed to stereo. If the left and right look different or are different sizes, then that could mean that there was a stereo affect applied to the audio, the original owner panned the sound before summing, or it is just a stereo sound. Use your judgement. If both channels look and sound completely identical, it's safe to split to mono and discard one of the channels. I usually just make the ones I don't need inactive instead of deleting anything.
www.HellfireBeats.com
UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61
Pro Tools 2021.12
Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2
16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1
27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15
A question about mono/stereo plug ins on mono tracks. rockguitarist1255 Pro Tools 10 2 12-24-2011 07:33 PM
one mono audio file when two mono tracks recorded bluerej Pro Tools M-Powered (Win) 0 02-06-2010 01:09 AM
one mono audio file when two mono tracks bluerej Pro Tools M-Powered (Win) 0 02-06-2010 01:06 AM
How to Create Stereo from Mono RussUK Virtual Instruments 1 08-03-2009 04:23 AM
How to create a Stereo track using one mono Soundboy99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-20-2001 11:56 AM
