#21
Re: HDX Latency
This seems to be a hit and miss issue. Most users are not seeing it. Those that are have not been able to offer a perfect 100% reproducible scenario. So...it's tough to rule out 3rd party plug-ins or pilot error.
And yes, it has been reported referencing this thread. Toggling ADC off then on again has been a simple solution here for me. Also, use Quickpunch as opposed to Normal if you feel you are experiencing ADC issues in Pre Roll while recording. If someone can offer a 100% reproducible case, please post it here.
#22
Re: HDX Latency
Same issues here.
#23
Re: HDX Latency
Any news bout this bug ? Had it a couple of times during the last recording sessions that the "talent" told me that "there's a delay" when he/she sings/plays.
Disabling and enabling DC did not help. I had to close the session and reload it. Then it worked for a while again - but it re-occured - mostly after record arming a different audio track. Very bad and it kills the talent's creativity !!!
Cheers, STeff --------------------------------------- MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected OSX10.15.7 Pro Tools|HDX Ultimate 2023.6 HD I/O&192Digital&96&96i I/Os D-Command ES 4xUnitor8 & 2xAMT8 |
#24
Re: HDX Latency
If this happens again... Toggle the ADC off then on again. At least this is a fast fix.
#25
Re: HDX Latency
#26
Re: HDX Latency
Yeah, late to the discussion here, but this has been driving me INSANE for the last year now.. To be honest, I had no idea how often this was happening, until I did a vocal session with the singer in the control room all day... It's happening literally, 60 to 70% of the time. Deactivate the track, and it's ok for a little while, and then back again. Seems that overdubbing into a complex mix with lots of delay comp, becomes a complete clusterf&@K. For example, recording an acoustic guitar with two microphones (neck - body) on grouped mono tracks, often results in one of the two channels having massive delay on 'Input'. Deactivating the tracks and reactivating seems to work about half of the time. Otherwise, close session, reboot, reopen session is the only recourse...
Totally unacceptable... |
#27
Re: HDX Latency
@wildhoneymusic http://kidzbop.com/music/ https://concord.com/publishing-roster/gary-philips/ |
#28
Re: HDX Latency
Yes ! Thing is , sometimes it does it on a track and if you record on the next one ( I often prepare a lot of tracks for BVs for ex) it doesn't happen .
It's a flow and creativity killer . You have to have TRUST in your DAW . I trusted PT but now I tend to think of the next time this is gonna happen . A HDX2 system is supposed to be very powerful . Wasn't HDX presented as 5 times the power of Accel ? If It can't figure out latency in the system I don't need that power . Did any of you try different delay compensation values to see if it happened at all settings ? I use maximum but I'm gonna try other values to see if I get that bug again . The shorter value is almost useless as a lot of plugs (waves tune , Autotune , gtr amp plugs) will produce more than 1000 samples at 256 or 512 buffer . As I said before when I use shorter buffer settings I sometimes get an error message asking to increase the buffer size . I don't recall those native plugins having so much latency on my TDM rig . I'll try and compare it next week . |
#29
Re: HDX Latency
I'll just add that I've been working at an outside studio for the last two days, using an HD Native system (PT 10HD) and getting this exact same behavior. Identical to what I get at my place on HDX (PT 10HD).
#30
Re: HDX Latency
yup a lot of folks are running into this problem, and it is totally unavoidable if you're using native plugs. and of course since many 3rd parties have abandoned AAX DSP plugs altogether we're [bleep]ed... nice.
the only thing you can do is yank your buffer down to 64 and cross your fingers... ps - ADC on HDX is a J.O.K.E. with native plugs. |
Automation latency when using plugins that have long latency | pyrodave | Pro Tools 11 | 2 | 01-27-2014 11:22 AM |
omni/native latency vs mbox pro latency | chrisdee | Pro Tools HDX & HD Native Systems (Win) | 34 | 03-30-2012 07:24 AM |
Latency Issues - changing latency has no effect | Kippa-Dee | Pro Tools M-Powered (Win) | 1 | 07-15-2010 08:39 PM |
Piano VI's- Latency Latency!! | MARVINBASS | Virtual Instruments | 5 | 04-27-2006 01:09 AM |
Unity DS-1 and Latency... Anyone else feel the latency makes the Plugin unusable? | Mt.Everest | Pro Tools TDM Systems (Mac) | 7 | 08-26-2001 04:53 PM |
