Old 01-29-2015, 08:23 PM
luts luts is offline
Default Seeking advice on MacBook Pro usability 2011 vs 2014
Hi there,
I'm tossing up between buying a MBPro 15" late 2011 SandyBridge or a more modern Ivy Bridge or Haswell Machine.
I can save $1K by going for the older machine.
The 2011 model I'm looking at is pre retina.. i7 2.5kHz. I can max the RAM out to 16Gb. It already has a 500gb SSD.
I want to run 2 ext displays and will be using Pro Tools 11 with Kontakt and sample libraries for midi composition to picture.
I like the idea of replacing the optical DVD drive for another SSD.
The main concerns about the 2011 machine are..
1. Will I run into trouble with the second external display? I will need to use USB converter and I'm concerned lag will be a problem.
2. Is a Sandy Bridge i7 2.5kHz going to be sufficient power for the things I need it for? ie.. running quite a few sample libraries and plugs,etc..
3. What bottlenecks am I likely to face vs a newer machine?
Any advice/experience is much appreciated.
Adam
Old 01-30-2015, 02:17 PM
Brother Junk Brother Junk is offline
Default Re: Seeking advice on MacBook Pro usability 2011 vs 2014
The new ones are the balls!
But you don't NEED it.
I'm successfully running PT 10,11, Logic X, TONS of plug-ins on
MacBook Pro (15", Early 2011)
2.2 Ghz Intel Core i7
8Gb 1333 Mhz DDR3
AMD Radeon HD 6750M 1024MB
& I don't have an SSD as my main drive. I have a TB as the main & I took the cd drive out & have a 500gb there instead.
I don't know if it's due to my ram but you will be limited to running too many tracks with too many plug-ins. It is a laptop after all, but I get away with it just fine.
At the studio we have Mac Pro's & we run into the same issue, but not until you are running 50+ tracks.
PT11HD on 2011 MacBook Pro ksgltd Pro Tools 11 13 01-11-2016 03:15 AM
2014 MacBook Pro for Editing Only TerryBarnett Pro Tools 11 2 12-17-2014 12:11 PM
Early 2011 MacBook Pro DJTezo411 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-27-2011 01:55 PM
ProTools 8.03 on Snow Leopard Plugin Usability advice Matt Darcy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-20-2010 08:32 AM
