Old 03-29-2019, 05:42 AM
Default Re: Video Cut Detection
Originally Posted by laki View Post
So, from what I understand, Nuendo and Resolve will Analyze the video file and determine scene cuts Automatically.
Ediload and Conformalizer need an EDL to do this. Which is cool but not as cool as the Resolve/Nuendo thingy.
Is this right?
Using EDLs is always the most accurate way to do it. (100% accurate). If you don't want to use EDLs you can use Conformalizer's video compare. Load the same QT into old and new players, set healing to "careful" and then do the video compare. That said, this won't be 100% accurate and depend on the type of film etc. and it will take MUCH longer than using EDLs (or is this an instant process in Nuendo or Resolve? I'd be surprised if this is faster than using EDLs or importing the video track from the AAF). This demo suggests a pretty long wait for a whole film and semi-manual threshold setting and error fixing.
But why use EDLs in the first place? You can simply ask for an offline AAF with the relevant video track from editorial and import that into PT. If you want to turn this into an audio guide with cut clips just use the separate clips on clips/markers-grid feature.
F.
PTHDn 2019.10 (OSX10.14.4), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM
Old 03-29-2019, 09:08 AM
Reckless Erik Reckless Erik is offline
Is this feature in PT Frank?
nickcath@internet.is
Newcomer Audio Post
MacBookPro 2.3GHz i7 16GB RAM OSX 10.14.6, PT 2019.10 HDn, Avid Artist Control, Avid Artist Mix...,
MacPro 3.5GHz 6 core 64GB RAM OSX 10.14.6, PT 2019.10 HDn, Avid Artist Control, Avid Artist Mix, PT Dock...
Old 03-29-2019, 09:54 AM
Yes. Set grid to Clips/Markers. Hide all other tracks apart from your cut video and your dummy audio track also hide the marker track. Select your dummy clip group and chose Edit/Separate Clip/On Grid.
I actually do it the other way around. I crate a screen change track with EC and then copy the cuts over to my QT. That way I can use the video universe window (command-7) to quickly visually navigate in the film (you get one thumbnail for every clip on the active video track). Unfortunately the Video Universe is a bit buggy (I guess no one uses it besides myself) but if you know the bugs it's very helpful. Poor man's NLE overview. PT has a lot to learn MC or any NLE with regards to project management and workflow.
F.
HTML code is On
tempo detection Darryn Farrugia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-26-2009 10:36 AM
Beat Detection March314 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-16-2005 08:42 AM
M BOX plug and play detection mbrewster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 04-09-2003 01:18 AM
Wacky detection of IDE devices ??? genebadd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 03-11-2003 10:57 AM
WAV length detection airon Digidesign Hardware & Software 2 01-15-2001 08:05 AM
