  #21
Old 01-09-2021, 10:17 AM
leftalive leftalive is offline
Default Re: Alternative to Waves MV2?
I love this plugin, but I do sometimes wish it didn't have the aggressive low mid bump (or that I could at least turn it off).
PC workstation:
Windows 10 Pro
i7 12700K
RTX 2080ti
64GB DDR5 5200mhz RAM
2 Samsung 980 Pro 1TB SSDs
Samsung 850 Pro 1TB SSD
LG 34" Ultra-Widescreen monitor
Pro Tools 12.4
A loaf of bread
A stick of butter
A lot of rye whiskey
  #22
Old 01-11-2021, 12:30 AM
simon.a.billington simon.a.billington is offline
Originally Posted by bad jitter View Post
From MV2's manual:
Low Level
Sets the low level compression threshold. Compression is applied to signals below this threshold. (From bottom up)
Range: 0 to +48 dBFS
I don't get how the threshold can be above 0 dBfs? As I understand it, the low-level slider sets the maximum amount of low level upwards compression. And that user cannot set the actual threshold at all.
What do you think?
I get what you are saying, the scale they've used is a little confusion. In related to standard top down compression you might more expect to see it marked -60 or -48dB and upwards, or something like that. The way they've done it does seem more practice, though.
With the standard compression its very easy to tell how much your shaving off the top, but it wouldn't be as user friendly if it started at -48, you'd have to do the maths in your head. It's not hard maths, but if you have to work for it then its not as fast, not as intuitive. So my guess is they used a dB scale that was more user friendly.
Also consider that if its reasonable for a compressor to reduce signals under a threshold beginning at 0, then the inverse of that rule most also be acceptable. Increasing levels over a threshold beginning at 0.
  #23
Old 01-12-2021, 09:05 PM
chrisdee's Avatar
chrisdee chrisdee is offline
Maxvolume form Waves is also an alternative. Its a bit cleaner sounding to my ears. It has a gate function in addition wich i find very usefull.
Boh Maxvolum and MV2 are great at evening out a dynamic signal.
But sometimes i feel they both sound kind of flat and steril compared to tracking with a hw compressor. Other times i think they sound more natural and less compressed cmpared to using outboard compression.
HTML code is On
Alternative to WAVES Blindman13 Pro Tools TDM Systems (Mac) 32 01-01-2015 06:52 AM
Waves Surround Bundle alternative garnoil Post - Surround - Video 8 06-02-2009 03:27 PM
Good alternative to waves L2 ? Ru_C Pro Tools TDM Systems (Mac) 18 09-20-2007 08:25 AM
Alternative to WAVES Plugins? SonicWorx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 02-18-2006 03:37 PM
alternative to buying waves bundles? woodbeatz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-10-2004 06:31 AM
