upgrade help needed please
I hope this is in the right place here, if not apologies.
OK I run PT 8.02 with Mbox2 pro on an iMac 3.4 ghz Intelcore I7 8GB OSX 10.7.5 I need to do updates on this computer as its also my work computer but am told my PT with not work if i do. I dont want to upgrade my PT to 10 or 11 or anything like that IM not an expert on this so all help will be appreciated. 1. Can i partition the hard drive and upgrade half of it for example and keep the other half for this? IF not 2. my other option is to buy a mac mini and run PT solely on that will that work ? if so what year/model etc do i need ? many thanks in advance for your help |
Re: upgrade help needed please
Your option 2 won't help you because unless you buy a used Mini you're going to get an OSX that won't work with your PT8. Is there any way that you could go the Mini route and use that as your work computer? That would allow you to keep your iMac machine for PT work. |
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
The amount of ram isn't affected as you can only run one partition at a time which would have access to the full amount of ram. As to expense that depends on what you're looking at for a laptop. Mac or PC? |
If the new computer comes with more current operating system, it is a no-go to keep the old system in a different partition. Apple does not back-port drivers and such to older operating systems (10.7.5 would need an update) so you just cannot use it.
So if you get a new computer, you will also need to buy PT12
Would i have to reinstall PT8? I trying to justify an expense i probably don't need at the moment so partitioning is how ill go |
Upgrade help needed please | rowdi | FireWire & USB Audio Interfaces (Mac) | 0 | 01-21-2017 08:50 AM |
Upgrade help needed please | rowdi | macOS | 6 | 05-02-2016 07:23 AM |
Upgrade Help needed | ThatDigiGuy | Pro Tools TDM Systems (Mac) | 6 | 06-13-2009 11:00 AM |
PT LE 6.4 XP RAM Upgrade Help Needed | JAMPROSOUND | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-07-2008 02:27 PM |
5.1.1 not needed for upgrade | j creasey | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-21-2002 06:53 AM |
