Old 12-27-2016, 03:34 PM
rossi68 rossi68 is offline
Default Command 8
Just had to share..
Found an old command 8 for 70$ online...
Hooked it up, started pro tools, choosed command 8 in pheripherals..
And...... it worked right away :)
Pro tools 12.6.1, win 10
Antelope Orion Studio 2017, UA 4-710, Presonus digimax FS, Sony DMX r100
Old 12-27-2016, 03:57 PM
AlexLakis AlexLakis is offline
Default Re: Command 8
Are you using the Command 8 as the audio interface, or just as a control surface? AFAIK, the latter in impossible?
Old 12-27-2016, 04:04 PM
YYR123's Avatar
YYR123 YYR123 is offline
It is only a surface - and a dang good one for $70
Daniel
Old 12-28-2016, 11:52 AM
Barry Johns Barry Johns is offline
Originally Posted by rossi68 View Post
Just had to share..
Wow, you got a great freakin' deal!!!!
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors.
MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp
Old 12-28-2016, 12:33 PM
Last I remembered, we tried to hook up a Command|8 for use as a control surface on my friend's PT9 rig with a Profire 2626 interface and it was nothin' doin'. What am I missing here?
Old 12-28-2016, 01:07 PM
YYR123's Avatar
I was using a command|8 since I moved from my Pro Control....and it is simply a control surface and works great for PT12.
It is not an interface and will have to be setup in the peripheral setup.
If your on windows it will most likely need a driver.
Daniel
Old 12-28-2016, 01:18 PM
Nevermind, it was a Pro Control I was remembering.
Old 12-30-2016, 12:40 PM
The driver seems to installed when you install pro tools. There was no driver installation when I started it the first time.
Only the setup in perpherals....
I think it can be used as a monitor controller, but I so far I use it as a control surface.
Updated to PT 12.7 yesterday and still its ok.
And yes, it was a really good deal :)
Any difference besides color between D Command and D Command ES? diamondschwin Pro Tools TDM Systems (Mac) 10 03-12-2012 12:15 PM
Command Keyboard Focus mode ' E ' command bug ? vudoo Pro Tools TDM Systems (Win) 2 09-10-2009 05:49 AM
Is it possible to use a Command 8 in combination with a D-Command? usastra ICON & C|24 2 05-03-2009 01:44 PM
Total Loss of Command 8 Command/Modifiers John Pisciotta ProControl, Control|24, Command|8 1 05-13-2005 10:30 AM
command 8 martian Post - Surround - Video 1 03-26-2004 05:23 PM
