my plextor burner has finally died. it had a good, hard working life.
i can send it away to be refurbished but wondered if anyone can recommend a replacement? thanks. |
LaCie d2 52x32x52 CD-RW. Just make sure your media is certified for the faster speeds.
The DVD Burners are cheap enough except for 1 problem.
They burn CD's a little slower. So if you burn alot of CD's and need them fast you might be better off with a CD Burner. I also put the new Pioneer DVD Burner in my G4 and it works great.
Pro Tools Tutorials: Mixing Heavy Rock & Metal • Pro Tools 11 - Tips and Tricks • Delay Explained • Tracking Rock - Drums • Mixing Rock • Music Production with Pro Tools • Pro Tools Tips and Tricks Vol. 2 • Pro Tools Tips and Tricks Vol. 3 • Elastic Audio in Action |
thanks for the replies but i need to know what's going to do audio as well as the plextor. (low error, low jitter, redbook type stuff).
i can just go out and buy any old drive for data perhaps i'll just get the plextor fixed... |
I may have a solution. I need details on the style and type you have. I have two of them here.
Email me directly if you need to..
Gregory Ives, Composer/Sound Designer/Musician http://www.gregives.com https://pro-labs.imdb.com/name/nm1170521/?ref_=sch_int Protools 2020.12 Ultimate HD Native Thunderbolt Avid HD IO Mac Pro 3.5GHz 6-Core Intel Xeon E5 64GB of Ram OSX Mojave 10.14.6, Digital Performer 9.5.2, Logic Pro X 10.5.1 |
![]() Quote:
Rip(extract) speeds are good, big cache (true burn speeds), throughput(s) are excellent on all!!! Not too bash Sony but they die too often for me!! |
![]() Quote:
I wouldn't have an old drive repaired (unless by repair, they mean replace with a new one - as is often the case). Tolerances, etc., on the old drive are going to get funky over time. It simply won't work as well as it ded when it was new. Lee Blaske |
Buy another Plextor. The word I got from reliable sources, people that build duplicators and deal with burners all the time, is that DO NOT use a DVD burner for professional audio since they are tweaked for DVDs and will cause errors with audio.. I just went through this and had a bunch of sample burns from different burners including DVD Burners tested.
Mac Pro: 3,1, 8 core, 6GB RAM. OS 10.6.8, Protools 10.3.8 TDM HD2 Accel. |
I've found through experience that the built in Pioneer dvd burner in my G5 will often turn out coasters when trying to burn audio CDs. I've never had ONE coaster when using my firewire La Cie. So the built in only burns DVDs from now on - which it does very well - no DVD coasters so far.
David Freiberg |
Need to replace the dead Plextor... Quick CD-R question | Burton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 08-31-2002 11:21 AM |
Plextor CD-RW 12/10/32 | SubLevel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 11-09-2000 12:20 AM |
$$$$ for PLEXTOR | LAMMM | Tips & Tricks | 3 | 10-08-1999 11:25 AM |
Using Plextor 8/20? | UltraJay | Digidesign Hardware & Software | 1 | 03-10-1999 10:58 AM |
Plextor CD-R | azuolas | Digidesign Hardware & Software | 1 | 08-20-1998 12:37 PM |
