Old 07-17-2004, 10:40 AM
Mark Wheaton Mark Wheaton is offline
Default Re: The Definitive PT 6.4 Bug List
you might check whether you have system commands for things like Expose on. this may affect commands in Pro Tools???
Old 07-17-2004, 11:14 AM
TLarvenz TLarvenz is offline
There also a half speed recording bug, which won't allow you to use the "wait for midi note" function. I also wonder why you can't do a separate region command when you're in volume graph mode. You can use alot of the other key commands that relate to editing waveforms, like trim, etc. but separate region is a no-go. And I still would love to see drag and drop from finder. I don't think that anyone could disagree that finder is much faster than project manager if you know what you're looking for. Even on my G5. Sorry about the wish list stuff. The DUC is strangely devoid of a current wish list thread....odd. Maybe Waves is behind this....
Tracey
www.melodiousthunk.net
Old 07-18-2004, 12:31 AM
Mt.Everest Mt.Everest is offline
There is the fade bug. When using trimmer, it changes the fade. Also annoying.
Heres the main thread: Fades Bug
Keep em coming!
MT
PT|HD4 Accel PCIx w Magma Chassis & 192 I/O
PT HD 9.0.5 - Mac Pro 8-Core 2.4Ghz Westmere 10.6.8
PT|HD 9.0.5 - MacMini Core-Duo, 10.6.8 - ProFire 2626
•••DON'T BELIEVE THE HYPE•••
•Use & Trust ø Cancellation!•
Old 07-18-2004, 02:21 PM
woodywho woodywho is offline
Has anyone come across the disappearing region or a random region slide while working w/ a waves plug-in??
Too make it more baffling is that I use "dual" monitors and while working w/ a waves plug (I always work with plugins on the mix screen.....habit) I notice on the edit screen either a region slides in the direction of the slider or it just simply disappears. Only w/ Waves does this happen!!
HD2 (non accel), G4-733mhz, 1.2 ram, PT 6.4
Have you seen my 2 inch reel??
HitBound Studios
Old 07-18-2004, 02:26 PM
gives's Avatar
gives gives is offline
Which version of the Waves PlugIn..? V4 or V5? I have heard from several people that the Waves V5 Waveshell is BUGGY!!
I am going to wait for an update..
Gregory Ives, Composer/Sound Designer/Musician
http://www.gregives.com
https://pro-labs.imdb.com/name/nm1170521/?ref_=sch_int
Protools 2020.12 Ultimate HD Native Thunderbolt Avid HD IO
Mac Pro 3.5GHz 6-Core Intel Xeon E5 64GB of Ram
OSX Mojave 10.14.6, Digital Performer 9.5.2, Logic Pro X 10.5.1
Old 07-18-2004, 02:29 PM
gives's Avatar
Hello,
I usually start a new post when I find a bug or erradic behavior in Protools. But there are sooo many of them lately that it seems like like Im posting something new everyday. And then Im always going into a rant because I find them at the worst possible times and it drives me crazy. Maybe we can all post things we are finding, and maybe some of them will be user error or someone could offer a fix or workaround.
I think this should also include OSX issues as well cuz a few of the things Im finding I think are PT/OSX interactions. Also, if a topic has been discussed already, a simple synopsis of the behavior and a link to the main post would suffice i think. Finally, it would be great for people to reply that that have seen similar behavior or have not to weed out system specific bugs. Lets try to stick to PT 6.3.2 and higher as well. So anyway, I'll start:
--Option-K (toggle auto-input/all-input) is very unstable. Sometimes I hit it 3 or 4 times in a row while record enabled and nothing changes. I have even looked at the menu command and anything having to do with monitoring is grayed out. Some mousing around usually brings it back up. And now Im also used to ALWAYS having to hold OPTION and hit K twice in a row for it to take affect, i.e. switch from auto-input to all-input.
Random grayed-out edit functions like copy and paste for no rhyme or reason. Some mousing or clicking around usually brings the edit commands back to life.
Noise spike/click at the end of recorded regions. This one has me baffled. Why PT would add a click 60samples before the end of the region perplexes me. The main post is here
Arrow keys bug which is here
I have many more, but figure Ill start slow and see if there is interest in this thread and if it grows.
thanks
MT
I am avoiding hot keys all together!
G
Old 07-18-2004, 02:39 PM
I am using 4.0_9!!
HitBound Studios
Old 07-19-2004, 08:51 AM
archtop archtop is offline
I've been able to reproduce a crash with audiosuite > gain> preview.
if I process it's o.k.
preview> crash
Old 07-20-2004, 12:01 PM
cjguitar cjguitar is offline
I've been having most of the bugs mentioned here. Hopefully they will be fixed soon.
A bug that's really annoying to me is when importing .wav files into an aif. session, I have to turn off "Auto Region Fade In/Out Length", or I get digital distortion at heads and tales of the .wav audio files, as well as when I start playing in the middle of them. The strange thing is that the digital distortion usually is the length of the auto fade in milleseconds.
Chris M. Jacobson, CAS
Re-recording Mixer, Sound Designer
IMDB
Old 07-20-2004, 03:12 PM
tomcat tomcat is offline
When hitting cmnd+opt+/ to write auotmation to all enabled parameters, the edit window sometimes (usually) jumps to the beginning of the session. The selection remains so i can get back to the region i was at, but this is big annoyance on a long project.
tom
www.tompaul.com
Blog: The Definitive List of Eleven Rack Tracks Chris Townsend Eleven Rack 51 06-05-2011 06:17 AM
Definitive Free RTAS Plug-in list here Caution767 Tips & Tricks 4 06-14-2009 09:39 PM
Definitive Free RTAS Plug-in list here Caution767 Tips & Tricks 3 06-10-2009 12:55 AM
Is there a definitive plug-in version list ? CCash Pro Tools TDM Systems (Mac) 1 08-17-2004 10:52 AM
TDM - LE s/w Definitive list of differences juzbag 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-21-2002 02:18 PM
