Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
  #21
Old 02-25-2021, 01:26 PM
uptheoctave uptheoctave is offline
Default Re: MTRX Studio and DVS Monitoring
Originally Posted by Marsdy View Post
Thanks James
Can the Focusrite be used by Logic/Live and Mac system at the same time or is it just one or the other? I don’t want to have to keep switching between the two.
The Focusrite, or any other native interface can be "Everything that isn't HDX" in your system, at once.
You just set it in Audi Midi Setup for system audio and then in the DAW's as an audio output.
James Richmond
https://www.jamesrichmond.com
2019 Mac Pro, 2022 Mac Studio Ultra
Avid S6, HDX2, MTRX II, MTRX, DAD AX64, AX32, Focusrite Rednet PCIER, Trinnov MC8 Pro.
Studio: https://www.voltperoctave.com | Music: https://www.euclideancircuits.com
Latest Article: Auto-Bounce for Logic Pro
Affiliate Links:
Auto-Bounce by Tom Salta
Dreamhost Web Hosting
  #22
Old 02-26-2021, 02:22 AM
robertszydlo robertszydlo is offline
Originally Posted by creativecontrol View Post
Depending on your use case.. If you don't need 64 channels of bidirectional audio connected between MTRX Studio and HDN, simply connect Port 1 of HDN to Port 1 of MTRX Studio, Port 2 of HDN to Primary Port on Omni (disable monitoring). Word Clock out of MTRX Studio -> into Word Clock in on HD Omni.
Jeff
I did and it works perfectly. The only drawback I can see for now is that in this setting I can see the omni in/outs from PT so I can use them in session as hardware inserts BUT I cannot see omni in/outs from DADman so I cannot use aes outs for monitoring. Will do for now but I clearly understand that in the end...either adding Penta or upgrading to big MTRX is the real way to go.
Again, thanks a lot! Have a wonderful weekend,
Robert
  #23
Old 03-02-2021, 11:41 PM
Marsdy Marsdy is offline
Thanks James that works great. Bye bye DVS!
Dave Marsden
UK
  #24
Old 04-05-2023, 04:11 PM
fiddlefro fiddlefro is offline
Hi there,
just found this while searching for similar issues.
I have a sort of solution for anyone still using Dante Virtual Soundcard or other Dante devices with a MTRX or MTRX Studio. I've written a soundFlow script which switches the sample rates for you in Dante Controller. All you have to do is set up preset files in Dante Controller with the devices you want set to each sample rate and name them accordingly. (It's explained athte beginning of the script).
For anyone who has this issue, I've been back and forth with Dante support, and they are simply not wiling or interested in adding a 'follow' sample rate' function to Dante Controller, which is what we REALLY need. Please email them a feature request as well! Maybe they will listen if there's enough grumbling from the mob!
File Type: pdf Missing Dante Controller Sample Rate Follow Script.pdf (29.8 KB, 0 views)
S6 and MTRX monitoring - Trinnov Dante Insert? acacia Avid S4/S6 8 08-22-2021 02:31 PM
MTRX Studio i/o Cheesehead Post - Surround - Video 9 02-21-2021 08:17 AM
MTRX Studio - AVB [email protected] Pro Tools | MTRX & MTRX Studio 3 02-03-2021 02:32 AM
MTRX Dolby Atmos monitoring using MADI Hosam Pro Tools | MTRX & MTRX Studio 3 11-06-2020 07:33 AM
MTRX Studio - No AES?! Ryan Young Pro Tools | MTRX & MTRX Studio 23 02-23-2020 02:13 PM
